跳转到主内容
The Claw Case Replacement
你所需要的
  1. The Claw Case Replacement, Top Cover: 步骤 1 中的图像 1,1
    • Place The Claw machine in the up-right position with the control knobs facing you.
  2. The Claw Case Replacement: 步骤 2 中的图像 1,1
    • Turn The Claw machine upside-down placing the top cover on the surface of your work area.
  3. The Claw Case Replacement: 步骤 3 中的图像 1,1
    • Remove all ten 6mm phillips #1 screws underneath the top cover using your #1 phillips head screwdriver.
    • It is helpful to choose a clear, well lit work space. There are multiple tiny screws that are easy to lose.
  4. The Claw Case Replacement: 步骤 4 中的图像 1,1
    • Turn The Claw machine back to the upright position with controls facing you.
  5. The Claw Case Replacement: 步骤 5 中的图像 1,1
    • Remove the top cover of The Claw machine.
  6. The Claw Case Replacement: 步骤 6 中的图像 1,2 The Claw Case Replacement: 步骤 6 中的图像 2,2
    • Remove the ten 6 mm phillips #1 screws from the top flange.
  7. The Claw Case Replacement: 步骤 7 中的图像 1,1
    • Lift the flange upward and off to the side of the machine.
    • There is enough wire connecting the flange to the machine that you will not need to cut the wire. The flange can be moved off to the side of the machine while you are working.
    • Cutting or ripping out the wire will cause damage to the machine so try not to put much tension on the wire.
  8. The Claw Case Replacement, Case: 步骤 8 中的图像 1,1
    • The glass you intend to replace will have four 6mm #1 phillips head screws on either side located in the silver corner pieces.
  9. The Claw Case Replacement: 步骤 9 中的图像 1,1
    • Loosen all eight screws using your phillips head #1 screwdriver so that the glass can be removed.
  10. The Claw Case Replacement: 步骤 10 中的图像 1,1
    • Gently remove the broken clear plastic case.
    • Remember how the case sat into the frame so that you can seat the new case in the same way.
结论
2等其他人完成本指南。
Alain Pierre
于03/22/16注册
1,188 声望
创作了9篇指南
团队
UMass Dartmouth, Team 4-8, Catania Spring 2016 UMass Dartmouth, Team 4-8, Catania Spring 2016 的会员
UMASSD-CATANIA-S16S4G8
3 名成员
创作了18篇指南
一条评论
where can i get the clear plastic panels
cristian2002 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 1,471
