跳转到主内容
The Claw Bottom Cover Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. The Claw Bottom Cover Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Place The Claw in upright position with controls facing you.
  2. The Claw Bottom Cover Replacement: 步骤 2 中的图像 1,1
    • Gently flip The Claw machine upside down with the controls facing you.
  3. The Claw Bottom Cover Replacement: 步骤 3 中的图像 1,1
    • Remove all ten screws from the bottom cover using a Phillips #1 screwdriver.
    • You will need a screwdriver with a long thin neck to fit in the screw holes.
  4. The Claw Bottom Cover Replacement: 步骤 4 中的图像 1,2 The Claw Bottom Cover Replacement: 步骤 4 中的图像 2,2
    • Slide the bottom cover off to the side.
    • Do not completely remove bottom cover as it is still connected to wires.
  5. The Claw Bottom Cover Replacement: 步骤 5 中的图像 1,1
    • Complete removal of the bottom cover is not necessary, however if you feel you need to take the cover completely off the machine to complete your task it can be done by the following process.
    • You will need to cut the two green wires attached to the music player.
    • Then you will need to cut the white wire that leads to the battery compartment.
    • Finally you will need to cut the black wire leading to the battery compartment as well.
    • The complete removal of the bottom cover requires the cutting and soldering of wires. For help with soldering reference: 如何焊接和拆焊.
结论
Alain Pierre
于03/22/16注册
1,188 声望
创作了9篇指南
团队
UMass Dartmouth, Team 4-8, Catania Spring 2016 UMass Dartmouth, Team 4-8, Catania Spring 2016 的会员
UMASSD-CATANIA-S16S4G8
3 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 54
