跳转到主内容
The Claw "Claw" Replacement
你所需要的
  1. The Claw  "Claw" Replacement, Top Cover: 步骤 1 中的图像 1,1
    • Place The Claw machine in the up-right position with the control knobs facing you.
  2. The Claw  "Claw" Replacement: 步骤 2 中的图像 1,1
    • Turn The Claw machine upside-down placing the top cover on the surface of your work area.
  3. The Claw  "Claw" Replacement: 步骤 3 中的图像 1,1
    • Remove all ten 6mm phillips #1 screws underneath the top cover using your #1 phillips head screwdriver.
    • It is helpful to choose a clear, well lit work space. There are multiple tiny screws that are easy to lose.
  4. The Claw  "Claw" Replacement: 步骤 4 中的图像 1,1
    • Turn The Claw machine back to the upright position with controls facing you.
  5. The Claw  "Claw" Replacement: 步骤 5 中的图像 1,1
    • Remove the top cover of The Claw machine.
  6. The Claw  "Claw" Replacement: 步骤 6 中的图像 1,2 The Claw  "Claw" Replacement: 步骤 6 中的图像 2,2
    • Remove the ten 6 mm phillips #1 screws from the top flange.
  7. The Claw  "Claw" Replacement: 步骤 7 中的图像 1,1
    • Lift the flange upward and off to the side of the machine.
    • There is enough wire connecting the flange to the machine that you will not need to cut the wire. The flange can be moved off to the side of the machine while you are working.
    • Cutting or ripping out the wire will cause damage to the machine so try not to put much tension on the wire.
  8. The Claw  "Claw" Replacement, Claw: 步骤 8 中的图像 1,1
    • Once you have removed the top cover of the claw you can easily access the claw and you will see that the claw is attached by two small chains.
    • Locate the small rings that attach the chain to the plastic claw.
  9. The Claw  "Claw" Replacement: 步骤 9 中的图像 1,1
    • Using the precision tweezers or small needle nose pliers, gently widen the small rings enough so that they can be removed from the claw.
    • Replace the claw one ring at a time. The chain needs to be attached to the new claw in the same configuration. One side of the chain opens the claw and the other side is just a hanging support.
    My claw machine has only one of the chains attached when I opened the box. The claw does not open because that chain is not attached.
    Ronnie Crumpton - 回复
    Addition to the above comment. The open chain is not attached to the gear box.
结论
2等其他人完成本指南。
Alain Pierre
于03/22/16注册
1,188 声望
创作了9篇指南
团队
UMass Dartmouth, Team 4-8, Catania Spring 2016 UMass Dartmouth, Team 4-8, Catania Spring 2016 的会员
UMASSD-CATANIA-S16S4G8
3 名成员
创作了18篇指南
6条评论
Where do I buy a new grabber thing
Oliver Chew - 回复
The 1st joystick that moves the claw forward and back doesn’t work.
Michelle Bianchini - 回复
What if the chain won't go down as it deep as it used to be?
Mira DIP - 回复
Can you reconnect the white cord in picture above in step 6 connecting the claw on top and bottom
Greg Sturges - 回复
My chain fell off and I dont know how to fix
Kathellyn Da silva - 回复
Porque la garra no sube ni baja +?
Pero a los lados si funciona!?
Gracias
BB᭄ᎷᎪQᎠᎬҒႮᎬ Bᴀʀʀɪᴏ᭄Bʀᴀᴠᴏ - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 85
总计 8,765
