跳转到主内容
The Beatles Rock Band Hofner Bass Whammy Bar Replacement
你所需要的
  1. The Beatles Rock Band Hofner Bass Whammy Bar Replacement, Back Plate: 步骤 1 中的图像 1,1
    • Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
    • Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
    • Use a J1 Phillips head screwdriver to remove four 5mm long screws.
  2. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: 步骤 2 中的图像 1,1
    • Flip the bass to the front, with the strummer and fret buttons facing you.
    • Use a J1 Phillips head screwdriver to remove two 10mm silver, short screws.
  3. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: 步骤 3 中的图像 1,2 The Beatles Rock Band Hofner Bass Whammy Bar Replacement: 步骤 3 中的图像 2,2
    • Flip the bass on its back again, so that the strummer is facing down and the battery compartment is facing you.
    • Pull off the back whole panel so that the bass is now open.
  4. The Beatles Rock Band Hofner Bass Whammy Bar Replacement, Whammy Bar: 步骤 4 中的图像 1,1
    • Use J1 Phillips screwdriver to remove the four 10mm screws on the whammy bars black cover.
  5. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: 步骤 5 中的图像 1,1
    • Remove the black cover.
    • Now the white whammy bar underneath is visible.
  6. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: 步骤 6 中的图像 1,2 The Beatles Rock Band Hofner Bass Whammy Bar Replacement: 步骤 6 中的图像 2,2
    • Use a J1 Philips head screwdriver to remove one 10mm screw.
    • This will unscrew the electrical connection between the whammy bar and the blue circuit board.
    • Remove the electrical connector.
  7. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: 步骤 7 中的图像 1,1
    • Remove the whammy bar, since nothing should be connecting to the guitar anymore.
结论
Jacob
于01/25/17注册
601 声望
创作了6篇指南
团队
Cal Poly, Team 8-4, Banghart Winter 2017 Cal Poly, Team 8-4, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S8G4
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 657
