跳转到主内容
The Beatles Rock Band Hofner Bass Directional Pad Replacement
你所需要的
  1. The Beatles Rock Band Hofner Bass Directional Pad Replacement, Back Plate: 步骤 1 中的图像 1,1
    • Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
    • Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
    • Use a J1 Phillips head screwdriver to remove four 5mm long screws.
  2. The Beatles Rock Band Hofner Bass Directional Pad Replacement: 步骤 2 中的图像 1,1
    • Flip the bass to the front, with the strummer and fret buttons facing you.
    • Use a J1 Phillips head screwdriver to remove two 10mm silver, short screws.
  3. The Beatles Rock Band Hofner Bass Directional Pad Replacement: 步骤 3 中的图像 1,2 The Beatles Rock Band Hofner Bass Directional Pad Replacement: 步骤 3 中的图像 2,2
    • Flip the bass on its back again, so that the strummer is facing down and the battery compartment is facing you.
    • Pull off the back whole panel so that the bass is now open.
  4. The Beatles Rock Band Hofner Bass Directional Pad Replacement, Directional Pad: 步骤 4 中的图像 1,2 The Beatles Rock Band Hofner Bass Directional Pad Replacement, Directional Pad: 步骤 4 中的图像 2,2
    • Use a J1 Phillips screwdriver to remove the six screws 10mm around the brown button cover.
  5. The Beatles Rock Band Hofner Bass Directional Pad Replacement: 步骤 5 中的图像 1,1
    • Remove the directional pad button,
结论
Jacob
于01/25/17注册
601 声望
创作了6篇指南
团队
Cal Poly, Team 8-4, Banghart Winter 2017 Cal Poly, Team 8-4, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S8G4
3 名成员
创作了6篇指南
一条评论
I need help re-assembling the Effect Switch. I have a tiny spring and steel ball that I don't know how to put back together.
Jay Kap - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 349
