跳转到主内容
The Beatles Rock Band Drum Set Drum Pad Replacement
你所需要的
  1. The Beatles Rock Band Drum Set Drum Pad Replacement, Drum Pad: 步骤 1 中的图像 1,2 The Beatles Rock Band Drum Set Drum Pad Replacement, Drum Pad: 步骤 1 中的图像 2,2
    • Pry the drum pad off of the drum set.
    • This will take significant force, but the rubber on the drum pad can withstand the force.
  2. The Beatles Rock Band Drum Set Drum Pad Replacement: 步骤 2 中的图像 1,2 The Beatles Rock Band Drum Set Drum Pad Replacement: 步骤 2 中的图像 2,2
    • Remove the small wire clip shown in the picture.
    • If this wire is already disconnected, that is most likely the cause for the drum pad not working.
  3. The Beatles Rock Band Drum Set Drum Pad Replacement: 步骤 3 中的图像 1,1
    • Remove the four Phillips size J0 screws supporting the hit sensor.
    • There is a small plastic disk and a spring in the support; be sure not to lose it.
  4. The Beatles Rock Band Drum Set Drum Pad Replacement: 步骤 4 中的图像 1,1
    • The sensor can be peeled off of the drum pad.
结论
2等其他人完成本指南。
Zach Richter
于01/24/17注册
549 声望
创作了5篇指南
团队
Cal Poly, Team 13-3, Banghart Winter 2017 Cal Poly, Team 13-3, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S13G3
4 名成员
创作了5篇指南
一条评论
Where can you buy replacement sensor?
Barry Howard - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 67
总计 7,915
