跳转到主内容
修复你的物品
维修的权力
商店
  1. 这个步骤还没有翻译 帮忙翻译一下
    Use the spudger to pry open the key fob shell by sliding it in between the front and back part of the key fob.
    • Use the spudger to pry open the key fob shell by sliding it in between the front and back part of the key fob.
  2. 这个步骤还没有翻译 帮忙翻译一下
    To remove the buttons, lift the "rubber button pad'' from the key fob shell.
    • To remove the buttons, lift the "rubber button pad'' from the key fob shell.
  3. 这个步骤还没有翻译 帮忙翻译一下
    Remove the old CR2032 battery by simply pulling it out and replace it with a new one.
    • Remove the old CR2032 battery by simply pulling it out and replace it with a new one.
  4. 这个步骤还没有翻译 帮忙翻译一下
    Insert rubber button pad over the battery. Place the front end of the key fob over the buttons and press down until you hear a "click".
    • Insert rubber button pad over the battery. Place the front end of the key fob over the buttons and press down until you hear a "click".
  5. 这个步骤还没有翻译 帮忙翻译一下
    Press the vehicle lock button to ensure all doors of the vehicle are locked.
    • Press the vehicle lock button to ensure all doors of the vehicle are locked.
  6. 这个步骤还没有翻译 帮忙翻译一下
    Insert key into the ignition.
    • Insert key into the ignition.
  7. 这个步骤还没有翻译 帮忙翻译一下
    Press and hold the unlock button on the driver side door. Do not release until prompted to do so in Step 10.
    • Press and hold the unlock button on the driver side door. Do not release until prompted to do so in Step 10.
  8. 这个步骤还没有翻译 帮忙翻译一下
    • Swiftly turn the ignition ON and OFF.
  9. 这个步骤还没有翻译 帮忙翻译一下
    Release the unlock button on the driver side door.  You should hear the vehicle automatically lock and then unlock.
    • Release the unlock button on the driver side door. You should hear the vehicle automatically lock and then unlock.
  10. 这个步骤还没有翻译 帮忙翻译一下
    Press the lock and unlock buttons on the key fob simultaneously until the vehicle automatically locks and unlocks (This can take approx. 30 secs.)
    • Press the lock and unlock buttons on the key fob simultaneously until the vehicle automatically locks and unlocks (This can take approx. 30 secs.)
  11. 这个步骤还没有翻译 帮忙翻译一下
    • Turn ignition on to exit programming mode.
  12. 这个步骤还没有翻译 帮忙翻译一下
    • Turn vehicle off and remove key.
  13. 这个步骤还没有翻译 帮忙翻译一下
    • Test key fob by pressing the lock/unlock buttons to ensure functionality.
终点
Tiara Bailey
于2020年02月03日注册
217 信誉积分
撰写一个指南
团队
添加评论
浏览统计数据:
过去的24小时: 3
过去的7天: 18
过去的30天: 85
总计 561
