跳转到主内容
The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide
你所需要的
  1. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide, The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: 步骤 1 中的图像 1,1
    • Use the spudger to pry open the key fob shell by sliding it in between the front and back part of the key fob.
  2. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: 步骤 2 中的图像 1,1
    • To remove the buttons, lift the "rubber button pad'' from the key fob shell.
  3. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: 步骤 3 中的图像 1,1
    • Remove the old CR2032 battery by simply pulling it out and replace it with a new one.
  4. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: 步骤 4 中的图像 1,1
    • Insert rubber button pad over the battery. Place the front end of the key fob over the buttons and press down until you hear a "click".
  5. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: 步骤 5 中的图像 1,1
    • Press the vehicle lock button to ensure all doors of the vehicle are locked.
  6. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: 步骤 6 中的图像 1,1
    • Insert key into the ignition.
  7. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: 步骤 7 中的图像 1,1
    • Press and hold the unlock button on the driver side door. Do not release until prompted to do so in Step 10.
    • Swiftly turn the ignition ON and OFF.
  8. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: 步骤 9 中的图像 1,1
    • Release the unlock button on the driver side door. You should hear the vehicle automatically lock and then unlock.
  9. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: 步骤 10 中的图像 1,1
    • Press the lock and unlock buttons on the key fob simultaneously until the vehicle automatically locks and unlocks (This can take approx. 30 secs.)
    • Turn ignition on to exit programming mode.
    • Turn vehicle off and remove key.
    • Test key fob by pressing the lock/unlock buttons to ensure functionality.
结论
另外一个人完成了本指南。
Tiara Bailey
于02/03/20注册
244 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 42
总计 4,053
