跳转到主内容
Texas Instruments TI-92 Display Replacement
你所需要的
  1. Texas Instruments TI-92 Display Replacement, Back Cover: 步骤 1 中的图像 1,3 Texas Instruments TI-92 Display Replacement, Back Cover: 步骤 1 中的图像 2,3 Texas Instruments TI-92 Display Replacement, Back Cover: 步骤 1 中的图像 3,3
    • The first step to any repair operation is to remove the front cover.
    • Grab the back of the calculator with one hand and the cover with the other.
    • Pull the cover off from one of the sides for easy removal.
  2. Texas Instruments TI-92 Display Replacement: 步骤 2 中的图像 1,2 Texas Instruments TI-92 Display Replacement: 步骤 2 中的图像 2,2
    • Orientate the calculator with the top facing towards you.
    • Slide the locking tab,found on the top part of the calculator, to the unlock position.
  3. Texas Instruments TI-92 Display Replacement: 步骤 3 中的图像 1,2 Texas Instruments TI-92 Display Replacement: 步骤 3 中的图像 2,2
    • "Locking Tab"
    • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
    • Then with the front of the calculator facing down, pull up on the back cover.
    • The calculator should now be orientated with the front facing down, as shown in picture 2.
  4. Texas Instruments TI-92 Display Replacement, Batteries: 步骤 4 中的图像 1,3 Texas Instruments TI-92 Display Replacement, Batteries: 步骤 4 中的图像 2,3 Texas Instruments TI-92 Display Replacement, Batteries: 步骤 4 中的图像 3,3
    • The Batteries are now exposed and the calculator is face down with the back towards you.
    • Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end.
    • If you can not do the previous step with your finger try using a flat ended tool such as an Ipod opening tool.
    • After the bottom battery has been removed push or slide the other(top) battery towards you until it is fully exposed in the battery slot.
    • Now simply remove the battery.
  5. Texas Instruments TI-92 Display Replacement, Texas Instruments TI-92 Back Case Disassembly: 步骤 5 中的图像 1,3 Texas Instruments TI-92 Display Replacement, Texas Instruments TI-92 Back Case Disassembly: 步骤 5 中的图像 2,3 Texas Instruments TI-92 Display Replacement, Texas Instruments TI-92 Back Case Disassembly: 步骤 5 中的图像 3,3
    • Using a Philips Screwdriver #00 unscrew the twelve 11.8mm screws shown in the picture and located on the back of the calculator.
  6. Texas Instruments TI-92 Display Replacement: 步骤 6 中的图像 1,1
    • Unscrew the 19mm screw located near center of the back of the calculator.
    • Remove the panel being held by the screw.
  7. Texas Instruments TI-92 Display Replacement: 步骤 7 中的图像 1,1
    • Using the same Phillips screwdriver, unscrew the remaining three 11.8mm screws.
  8. Texas Instruments TI-92 Display Replacement: 步骤 8 中的图像 1,2 Texas Instruments TI-92 Display Replacement: 步骤 8 中的图像 2,2
    • Using the Ipod Opening Tool pull up on both sides of the rectangular module while keeping the rest of the calculator flat on a surface face down
    • You may get a lot of resistance from the module. Do not use too much force as you risk damage. Use small amounts of force to work the module out.
  9. Texas Instruments TI-92 Display Replacement: 步骤 9 中的图像 1,2 Texas Instruments TI-92 Display Replacement: 步骤 9 中的图像 2,2
    • Pull out the rectangular module when it is finally loose enough.
  10. Texas Instruments TI-92 Display Replacement: 步骤 10 中的图像 1,2 Texas Instruments TI-92 Display Replacement: 步骤 10 中的图像 2,2
    • Now pull up on the back cover of the calculator while holding the rest of it flat on a surface.
    • Be careful not to tilt the front of the calculator at this point. The keyboard buttons are now unsupported and will fall out of place.
  11. Texas Instruments TI-92 Display Replacement, Motherboard: 步骤 11 中的图像 1,3 Texas Instruments TI-92 Display Replacement, Motherboard: 步骤 11 中的图像 2,3 Texas Instruments TI-92 Display Replacement, Motherboard: 步骤 11 中的图像 3,3
    • Pull the motherboard up while holding the rest of the calculator firmly in place
    • The motherboard has now separated from the rest of the calculator
  12. Texas Instruments TI-92 Display Replacement, Display: 步骤 12 中的图像 1,1
    • Place the motherboard flat on a surface with the LCD screen facing down.
    • Using a #00 Philip Screwdriver remove the screw located on the left side of a spring-like object located near the center of the motherboard.
  13. Texas Instruments TI-92 Display Replacement: 步骤 13 中的图像 1,2 Texas Instruments TI-92 Display Replacement: 步骤 13 中的图像 2,2
    • Lift up on the material covering the motherboard starting from the upper right corner. Peel foil back only about half way down.
    • Make sure to slowly lift up on the plastic of the covering material and not the foil or the foil will rip.
  14. Texas Instruments TI-92 Display Replacement: 步骤 14 中的图像 1,2 Texas Instruments TI-92 Display Replacement: 步骤 14 中的图像 2,2
    • Now slowly lift up the black tape located at the top of the calculator.
    • You will need to replace tape if removed so if you do not have this replacement part do not attempt to remove it
  15. Texas Instruments TI-92 Display Replacement: 步骤 15 中的图像 1,3 Texas Instruments TI-92 Display Replacement: 步骤 15 中的图像 2,3 Texas Instruments TI-92 Display Replacement: 步骤 15 中的图像 3,3
    • Tilt the calculator up from the front so that you can see the LCD screen
    • Finish removing the black tape on this side of the motherboard.
  16. Texas Instruments TI-92 Display Replacement: 步骤 16 中的图像 1,1
    • Do not know next step
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 15-51, Garner Spring 2010 Cal Poly, Team 15-51, Garner Spring 2010 的会员
CPSU-GARNER-S10S15G51
5 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 46
总计 9,180
