简介
If your screen Or motherboard is broken this guide is for you. The screen is tethered to the motherboard, so both items must be replaced at the same time.
  1. Remove the battery cover. Remove the AAA batteries from the calculator.
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Use plastic opening tool to remove the backup battery.  Place the tool in the small cut-out next to the battery and pry the battery out.
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
  4. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
    • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
  6. Pry back case off.  Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart. Pry back case off.  Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
    • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
  7. Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out. Remove the eight (8) 5mm Philips #00  screws on the motherboard.
    • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
    • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
  8. Carefully remove the motherboard and screen.  Grab the board by its side with one hand and the screen with the other.  Carefully lift the two parts up. Keep the face-plate face-down to prevent the keys from falling out.
    • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
      • Keep the face-plate face-down to prevent the keys from falling out.
结论
16等其他人完成本指南。
Kevin
于2012年10月02日注册
374 信誉积分
撰写一个指南
团队
Cal Poly, Team 18-37, Regan Fall 2012 Cal Poly, Team 18-37, Regan Fall 2012 的会员
CPSU-REGAN-F12S18G37
5 名成员
创作了5篇指南
Does anyone have any advice on acquiring replacement screens for the TI series? I was considering buying broken TIs on e-bay, but that may be unreliable.
Neil Cammardella - 回复
Fixing TI83+'s is becoming addictive. Google Cemetech Forum on the net and see how he removes the screen from the Mother Board and solders wires permanently. I might add that he tests for resistance (ohms) first to determine if in fact that is where the problems exist. If I read between the lines, he tends to think that the screen/mother board ribbon cable is the primary culprit behind problems with the TI83's
shrinertom@yahoo.com
shrinertom -
My TI-83 Plus, the screen has turned Black, like to know where to send it to have it repaired e-mail address, (BagManOne@ecite.com)
Richard Brown - 回复
Nothing is broken, the screen has turned Black, need to send it off and have it fixed, I can not do it my self because of the condition of my hands
Richard Brown -
It may not be broken. Try adjusting the screen contrast down.
Matthew Johnson -
浏览统计数据:
过去的24小时: 14
过去的7天: 78
过去的30天: 330
总计 39,777
