跳转到主内容
Texas Instruments TI-83 Plus Keyboard Mat Replacement
你所需要的
  1. Texas Instruments TI-83 Plus Keyboard Mat Replacement, Backup Battery: 步骤 1 中的图像 1,2 Texas Instruments TI-83 Plus Keyboard Mat Replacement, Backup Battery: 步骤 1 中的图像 2,2
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Texas Instruments TI-83 Plus Keyboard Mat Replacement: 步骤 2 中的图像 1,1
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Texas Instruments TI-83 Plus Keyboard Mat Replacement: 步骤 3 中的图像 1,1
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
  4. Texas Instruments TI-83 Plus Keyboard Mat Replacement, Back Case: 步骤 4 中的图像 1,1
    • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
  5. Texas Instruments TI-83 Plus Keyboard Mat Replacement: 步骤 5 中的图像 1,2 Texas Instruments TI-83 Plus Keyboard Mat Replacement: 步骤 5 中的图像 2,2
    • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
  6. Texas Instruments TI-83 Plus Keyboard Mat Replacement, Motherboard & Screen: 步骤 6 中的图像 1,2 Texas Instruments TI-83 Plus Keyboard Mat Replacement, Motherboard & Screen: 步骤 6 中的图像 2,2
    • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
    • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
  7. Texas Instruments TI-83 Plus Keyboard Mat Replacement: 步骤 7 中的图像 1,2 Texas Instruments TI-83 Plus Keyboard Mat Replacement: 步骤 7 中的图像 2,2
    • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
    • Keep the face-plate face-down to prevent the keys from falling out.
  8. Texas Instruments TI-83 Plus Keyboard Mat Replacement, Keyboard Mat: 步骤 8 中的图像 1,2 Texas Instruments TI-83 Plus Keyboard Mat Replacement, Keyboard Mat: 步骤 8 中的图像 2,2
    • Remove light gray rubber keyboard mat.
    • Keep your calculator face down to ensure the individual keys do not fall out.
  9. Texas Instruments TI-83 Plus Keyboard Mat Replacement: 步骤 9 中的图像 1,1
    • Clean the contacts on the keyboard with a soft cloth.
结论
另外一个人完成了本指南。
corey
于10/02/12注册
11 声望
撰写一个指南
团队
Cal Poly, Team 18-37, Regan Fall 2012 Cal Poly, Team 18-37, Regan Fall 2012 的会员
CPSU-REGAN-F12S18G37
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 4,596
