跳转到主内容
Texas Instruments TI-83 Plus Backup Battery Replacement
你所需要的
  1. Texas Instruments TI-83 Plus Backup Battery Replacement, Backup Battery: 步骤 1 中的图像 1,2 Texas Instruments TI-83 Plus Backup Battery Replacement, Backup Battery: 步骤 1 中的图像 2,2
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Texas Instruments TI-83 Plus Backup Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Texas Instruments TI-83 Plus Backup Battery Replacement: 步骤 3 中的图像 1,1
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
结论
Clay
于10/01/12注册
38 声望
撰写一个指南
团队
Cal Poly, Team 18-37, Regan Fall 2012 Cal Poly, Team 18-37, Regan Fall 2012 的会员
CPSU-REGAN-F12S18G37
5 名成员
创作了5篇指南
一条评论
Will this wipe the memory?
John Osborne - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 22
过去 30 天: 100
总计 21,027
