跳转到主内容
Texas Instruments TI-80 Motherboard and Screen Replacement
你所需要的
  1. Texas Instruments TI-80 Motherboard and Screen Replacement, Batteries: 步骤 1 中的图像 1,1
    • Locate battery cover on the back of the case.
    • Slide battery cover to the right reveal the batteries.
  2. Texas Instruments TI-80 Motherboard and Screen Replacement: 步骤 2 中的图像 1,1
    • Remove battery cover.
    • Slide the red lock down.
    • Slide the metal tab to the right of the top battery.
    • Remove the 3-Volt Lithium Coin Cell Battery.
    • Slide the red lock up.
    • Slide the metal tab to the right of the bottom battery.
  3. Texas Instruments TI-80 Motherboard and Screen Replacement, Back Case: 步骤 3 中的图像 1,3 Texas Instruments TI-80 Motherboard and Screen Replacement, Back Case: 步骤 3 中的图像 2,3 Texas Instruments TI-80 Motherboard and Screen Replacement, Back Case: 步骤 3 中的图像 3,3
    • Using a Torx, T-6 star-bit screwdriver, unscrew four 7.38 mm screws from battery housing.
    • Unscrew four 7.15 mm screws from back casing.
    • Using the blue plastic opener tool along the seam of the case, pry off front casing.
    • Start prying from the bottom of the calculator as the casing hooks into the top.
  4. Texas Instruments TI-80 Motherboard and Screen Replacement, Motherboard and Screen: 步骤 4 中的图像 1,2 Texas Instruments TI-80 Motherboard and Screen Replacement, Motherboard and Screen: 步骤 4 中的图像 2,2
    • Using a Philips PH0 screwdriver, remove the 6 screws. 2 from the top of the Motherboard, 2 from the middle, and 2 from the bottom of the Motherboard.
    • Using a Phillips Ph0 screwdriver, remove 4 screws from the screen mount.
    • Using the blue plastic opening tool, pry the Motherboard up.
    • Using the blue plastic opening tool, pry up the screen from the screen mount.
结论
brian decater
于01/13/15注册
301 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 12
总计 580
