跳转到主内容
Texas Instruments TI-5130 Printer Unit Replacement
你所需要的
  1. Texas Instruments TI-5130 Printer Unit  Replacement, Printer Unit: 步骤 1 中的图像 1,2 Texas Instruments TI-5130 Printer Unit  Replacement, Printer Unit: 步骤 1 中的图像 2,2
    • Flip the calculator over and remove the 4 main 10mm screws with a PH1 screwdriver.
  2. Texas Instruments TI-5130 Printer Unit  Replacement: 步骤 2 中的图像 1,1
    • Flip the calculator back over and remove the top cover.
  3. Texas Instruments TI-5130 Printer Unit  Replacement: 步骤 3 中的图像 1,1
    • Disconnect the printing unit from the motherboard by pulling up on the connector – located in the bottom left of the motherboard.
  4. Texas Instruments TI-5130 Printer Unit  Replacement: 步骤 4 中的图像 1,1
    • Remove the ink cartridge by pushing the tab back then lifting it out to gain access to the screw that holds the printer in place.
  5. Texas Instruments TI-5130 Printer Unit  Replacement: 步骤 5 中的图像 1,2 Texas Instruments TI-5130 Printer Unit  Replacement: 步骤 5 中的图像 2,2
    • Using a PH1 screwdriver remove the 10mm screw that holds down the printer unit.
    • Remove the printer unit by lifting it up.
结论
3等其他人完成本指南。
Shannon Perkins
于09/17/15注册
652 声望
创作了3篇指南
团队
2条评论
wehre did you buy the replacement printer
Tino ullrich - 回复
what sources are there for TI-5130 printer unit?
Norman Todd - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 21
总计 2,359
