跳转到主内容
Texas Instruments TI-5130 Power Cord Replacement
你所需要的
  1. Texas Instruments TI-5130 Power Cord Replacement, Power Cord: 步骤 1 中的图像 1,2 Texas Instruments TI-5130 Power Cord Replacement, Power Cord: 步骤 1 中的图像 2,2
    • Flip the calculator over and remove the 4 main 10mm screws with a PH1 screwdriver.
  2. Texas Instruments TI-5130 Power Cord Replacement: 步骤 2 中的图像 1,2 Texas Instruments TI-5130 Power Cord Replacement: 步骤 2 中的图像 2,2
    • Remove the top cover.
    • Gently pull up on the power cord to remove it from the back cover.
  3. Texas Instruments TI-5130 Power Cord Replacement: 步骤 3 中的图像 1,2 Texas Instruments TI-5130 Power Cord Replacement: 步骤 3 中的图像 2,2
    • This step is optional; however it makes it easier to work.
    • Using a PH1 screwdriver remove the two 10mm screws that hold down the transformer.
    • Gently remove the transformer.
    • Make sure that the calculator is not plugged in.
  4. Texas Instruments TI-5130 Power Cord Replacement: 步骤 4 中的图像 1,2 Texas Instruments TI-5130 Power Cord Replacement: 步骤 4 中的图像 2,2
    • Use a wire cutter to cut off the white cap and expose the wires. Try to cut close to the tip of the white cap - to leave as much wire as possible.
    • Note that there are 2 sets of wires connected to the power cord. Do each set of wires separately.
  5. Texas Instruments TI-5130 Power Cord Replacement: 步骤 5 中的图像 1,2 Texas Instruments TI-5130 Power Cord Replacement: 步骤 5 中的图像 2,2
    • Use a wire stripper to remove 1/2” of the protective covering on each of the wires.
  6. Texas Instruments TI-5130 Power Cord Replacement: 步骤 6 中的图像 1,2 Texas Instruments TI-5130 Power Cord Replacement: 步骤 6 中的图像 2,2
    • Twist the exposed section of the 2 wires together.
    • Twist a new cap over the exposed wires. Make sure that the cap covers all of the exposed wire.
    • Repeat steps 4-6 for the second set of wires.
  7. Texas Instruments TI-5130 Power Cord Replacement: 步骤 7 中的图像 1,1
    • Replace the transformer and ensure that the new wire caps fit in the space shown.
    • Plug in the new power cord and test the calculator before replacing the top cover.
结论
另外一个人完成了本指南。
Shannon Perkins
于09/17/15注册
652 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 499
