跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Texas Instruments TI-30Xa Battery Replacement
你所需要的
  1. Texas Instruments TI-30Xa Battery Replacement, TI-30XA Battery Replacement: 步骤 1 中的图像 1,1
    • Here's the fully assembled TI-30XA calculator.
  2. Texas Instruments TI-30Xa Battery Replacement: 步骤 2 中的图像 1,2 Texas Instruments TI-30Xa Battery Replacement: 步骤 2 中的图像 2,2
    • Locate the six screws on the back of the calculator.
    • With a Phillips #1 screwdriver, loosen and remove the screws.
  3. Texas Instruments TI-30Xa Battery Replacement: 步骤 3 中的图像 1,3 Texas Instruments TI-30Xa Battery Replacement: 步骤 3 中的图像 2,3 Texas Instruments TI-30Xa Battery Replacement: 步骤 3 中的图像 3,3
    • Find the two notches at the top of the calculator.
    • Insert a flat-head screwdriver into one of the notches and carefully pry open the top end of the case.
    • Locate where the case is still attached at the sides.
    • Insert the flat-head screwdriver into one side where the gap has widened.
    • Now gently pry apart the sides of the case.
    • Prying only one side will release the other side as well.
  4. Texas Instruments TI-30Xa Battery Replacement: 步骤 4 中的图像 1,1
    • Now separate the two panels from one another.
  5. Texas Instruments TI-30Xa Battery Replacement: 步骤 5 中的图像 1,2 Texas Instruments TI-30Xa Battery Replacement: 步骤 5 中的图像 2,2
    • The batteries are located at the top.
    • Slide the flat-head screwdriver underneath each battery and they will easily pop out.
结论
55等其他人完成本指南。
Chris L
于12/17/14注册
1,522 声望
创作了3篇指南
30条评论
Thanks for the guide! :) Worked! (Although they didn't engineer the case to come apart easily...)
Scott Julien - 回复
I'm so glad I looked this up. VERY helpful. A simple Google search indicated that it took a 3 volt, flat 'coin' style battery. These batteries, however - I actually have in my desk at work in a 3 pack. No need to even take a trip to the store now. Oh, BTW - the 3 pack was purchased from Walgreens. They sell them in a 3 pack for around $10.
Dewellah - 回复
Nice post! My batteries just gave up after 15 years. This whole time I tht it was a solor calc, LOL! Thanks for the easy instructions.
lasharlavenue - 回复
I changed the batteries and instructions on circuit board says to "please short the reset pad after changing the batteries ". How do I do that?
Esther Reese - 回复
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 130
过去 30 天: 703
总计 113,849
