跳转到主内容
Testing the Starbucks Barista Heating Element
你所需要的
  1. Testing the Starbucks Barista Heating Element, Testing the Starbucks Barista Heating Element: 步骤 1 中的图像 1,2 Testing the Starbucks Barista Heating Element, Testing the Starbucks Barista Heating Element: 步骤 1 中的图像 2,2
    • Remove the 6 Phillips #1 screws from the back panel.
    • Remove the back panel.
  2. Testing the Starbucks Barista Heating Element: 步骤 2 中的图像 1,1
    • Make sure the machine is turned off and unplugged.
    • Set your voltmeter in continuity mode and place the leads on the two 90 degree prongs on the boiler's heating element.
    • It does not matter which lead touches which prong as you're just testing for a break, or "open" in the heating element circuit.'''
    • If the voltmeter shows 0, or "open", then there is an issue with the heating element's continuity and it needs to be replaced.
    • If given a reading, then your heating element is fine.
  3. Testing the Starbucks Barista Heating Element: 步骤 3 中的图像 1,1
    • In the water reservoir, place mixture of de-calcifying agent and water as directed on the product label.
    • Place a cup, to catch fluid, underneath the portafilter.
    • Run Barista, as if making coffee, for the amount of time directed by the de-calcifying product.
    • See the links section of the device page for further directions.
    Consider adding a step to remove the slide on wire connectors to the heater terminals before testing.
    laryball - 回复
结论
11等其他人完成本指南。
Brian McMurray
于01/31/11注册
213 声望
撰写一个指南
团队
Cal Poly, Team 4-42, Regan Winter 2011 Cal Poly, Team 4-42, Regan Winter 2011 的会员
CPSU-REGAN-W11S4G42
4 名成员
创作了5篇指南
6条评论
I did this a few months ago and the boiler was full of rusty gunk. This guide sure did help me out.
oguitar200 - 回复
the same here - it was disgusting... was afraid to have damaged it while cleaning it. tested it yesterday already... just going through all the steps to validate function of the units.
Martin Zeitler -
hi ! we have Starbucks Barisa Milano. some how it didnt want switch on! my husband wanted to have a look but we cant open. do you gave any guidence?
Zorigoo Purev - 回复
I have a Barista and want to change the pressure washer of the coffee maker arm.
can any one help me?
sonnynima - 回复
I feel the temperature of the espressos i’m making is not hot enough. How do i raise the thermostat to activate the Ready light at a higher temp?
Tim Furnish - 回复
The Barista doesn't have a way to adjust the brew temp. But, if you preheat the portafilter and your cup (by running an empty shot of hot water) that will help you make the best of the situation. And, the target temp for espresso brewing is not 212- it's about 190-195 degrees.
Phil Van Kirk -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 20,621
