跳转到主内容
Tent Pole Shock Cord Replacement
你所需要的
  1. Tent Pole Shock Cord Replacement, Tent Pole Shock Cord: 步骤 1 中的图像 1,1
    • Remove the old shock cord from the tent poles.
  2. Tent Pole Shock Cord Replacement: 步骤 2 中的图像 1,1
    • Measure and cut the string to the length of one tent pole piece.
    • Be sure to leave enough room on each end for knots.
  3. Tent Pole Shock Cord Replacement: 步骤 3 中的图像 1,1
    • Tie the string to the end of the shock cord.
  4. Tent Pole Shock Cord Replacement: 步骤 4 中的图像 1,2 Tent Pole Shock Cord Replacement: 步骤 4 中的图像 2,2
    • Use your hands or pliers to flatten out a bobby pin.
    • Any long, thin, metal object will work to help feed the string and cord through the poles.
  5. Tent Pole Shock Cord Replacement: 步骤 5 中的图像 1,1
    • Tie the string around the end of the bobby pin.
    • The string and bobby pin will be used to feed the shock cord through the pole.
  6. Tent Pole Shock Cord Replacement: 步骤 6 中的图像 1,3 Tent Pole Shock Cord Replacement: 步骤 6 中的图像 2,3 Tent Pole Shock Cord Replacement: 步骤 6 中的图像 3,3
    • Drop the bobby pin and string through the tent pole pieces one by one.
    • Once the bobby pin reaches the opposite end of each pole, slowly pull the string to feed the shock cord through.
  7. Tent Pole Shock Cord Replacement: 步骤 7 中的图像 1,2 Tent Pole Shock Cord Replacement: 步骤 7 中的图像 2,2
    • Once the last piece has been threaded, untie or cut the string from the shock cord.
    • Tie a large knot against the right end of the last piece.
    • The knot must be large enough to prevent the shock cord from slipping through the pole.
  8. Tent Pole Shock Cord Replacement: 步骤 8 中的图像 1,2 Tent Pole Shock Cord Replacement: 步骤 8 中的图像 2,2
    • Connect the tent poles.
  9. Tent Pole Shock Cord Replacement: 步骤 9 中的图像 1,1
    • Cut the shock cord from the left end of the first pole piece leaving room on the end for knots.
    • Leaving extra shock cord on the end will also allow you to adjust the tension in the shock cord later on.
  10. Tent Pole Shock Cord Replacement: 步骤 10 中的图像 1,2 Tent Pole Shock Cord Replacement: 步骤 10 中的图像 2,2
    • Tie a large knot around the tent pole end piece.
    • Fit the end piece into the left end of the first pole.
    • If your poles do not come with an end piece, simply tie a large knot in the shock cord. The knot must be large enough to prevent the shock cord from pulling through.
  11. Tent Pole Shock Cord Replacement: 步骤 11 中的图像 1,1
    • Disconnect the pole pieces.
    • Fold the pieces to test the shock cord tension.
    • If the shock cord is too tight, reconnect the poles and adjust the shock cord length between the left end of the first pole and the end piece.
结论
3等其他人完成本指南。
Kelsea Weber
于11/12/15注册
19,857 声望
创作了32篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,722篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 28
总计 20,361
