跳转到主内容
Tennis Racket Bumper Guard Replacement
你所需要的
  1. Tennis Racket Bumper Guard Replacement, Tennis Racket Bumper Guard: 步骤 1 中的图像 1,1
    • Place the tennis racket on a big and comfortable surface. An empty table will be ideal.
  2. Tennis Racket Bumper Guard Replacement: 步骤 2 中的图像 1,3 Tennis Racket Bumper Guard Replacement: 步骤 2 中的图像 2,3 Tennis Racket Bumper Guard Replacement: 步骤 2 中的图像 3,3
    • Use your cutting tool to cut the racket strings.
    • Cut the strings one at a time.
  3. Tennis Racket Bumper Guard Replacement: 步骤 3 中的图像 1,1
    • Finish cutting all of the strings off.
    • No pattern necessary. Make sure all of the strings are cut.
    • Can be cut from the center or closer to the sides of the racket.
  4. Tennis Racket Bumper Guard Replacement: 步骤 4 中的图像 1,2 Tennis Racket Bumper Guard Replacement: 步骤 4 中的图像 2,2
    • Remove the strings by pulling from the outside of the racket.
  5. Tennis Racket Bumper Guard Replacement: 步骤 5 中的图像 1,1
    • This is how the tennis racket will look like when all of the strings are removed.
  6. Tennis Racket Bumper Guard Replacement: 步骤 6 中的图像 1,2 Tennis Racket Bumper Guard Replacement: 步骤 6 中的图像 2,2
    • Push the tubes(the ones that go through the racket frame) from the inside of the racket to remove the old grommets and the bumper guard. You may use your thumbs.
    • Use and edge of your cutting tool to push the tubes out if necessary.
    • Some of the tubes might be too stiff and won't come out that easily. Use a cutting tool to avoid hurting your thumb.
  7. Tennis Racket Bumper Guard Replacement: 步骤 7 中的图像 1,2 Tennis Racket Bumper Guard Replacement: 步骤 7 中的图像 2,2
    • As you push the tubes from the bumper guard and grommets they will start to come out.
    • The second picture shows the bumper guard and grommets completely removed.
    • Depending on your tennis racket another grommet might located at the base of the racket represented by the orange mark up. Remove it if it is present.
  8. Tennis Racket Bumper Guard Replacement: 步骤 8 中的图像 1,1
    • Prepare a set of new bumper guards and grommets.
  9. Tennis Racket Bumper Guard Replacement: 步骤 9 中的图像 1,2 Tennis Racket Bumper Guard Replacement: 步骤 9 中的图像 2,2
    • Align the bumper guard with the middle of the racket .
    • Push the top of the bumper guard onto the racket. Make sure that the tubes fit through the holes all the way.
  10. Tennis Racket Bumper Guard Replacement: 步骤 10 中的图像 1,3 Tennis Racket Bumper Guard Replacement: 步骤 10 中的图像 2,3 Tennis Racket Bumper Guard Replacement: 步骤 10 中的图像 3,3
    • This is how the finished tennis racket will look like.
    • Make sure all the tubes in the bumper guard and grommets go completely through as shown in the close up images.
结论
Now you can take your tennis racket to get restrung and you should have a finished racket.
2等其他人完成本指南。
Saul Hernandez
于10/26/17注册
140 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 37
总计 3,549
