跳转到主内容
Tengda S5 Plus Speakers Replacement
你所需要的
  1. Tengda S5 Plus Speakers Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Place the phone screen-side down.
  2. Tengda S5 Plus Speakers Replacement: 步骤 2 中的图像 1,2 Tengda S5 Plus Speakers Replacement: 步骤 2 中的图像 2,2
    • Using your fingernail or any prying tool (we used the Metal Spudger), begin to pry away the back panel starting at the bottom of the phone.
    • Continue to work your way around the phone counterclockwise until you can pull the back cover off.
  3. Tengda S5 Plus Speakers Replacement, Speakers: 步骤 3 中的图像 1,1
    • Using either your thumb or an iFixit opening tool, remove the battery and set it aside.
  4. Tengda S5 Plus Speakers Replacement: 步骤 4 中的图像 1,1
    • Unscrew the twelve 3 mm screws from the back panel using a Phillips #00 screwdriver.
  5. Tengda S5 Plus Speakers Replacement: 步骤 5 中的图像 1,2 Tengda S5 Plus Speakers Replacement: 步骤 5 中的图像 2,2
    • Using the plastic opening tool, create space between the front screen and the metal casing.
    • Once the screen is separated from the back panel, pull the two pieces apart.
  6. Tengda S5 Plus Speakers Replacement: 步骤 6 中的图像 1,2 Tengda S5 Plus Speakers Replacement: 步骤 6 中的图像 2,2
    • Using an iFixit opening tool, remove the speakers.
    • Do not be afraid to use a little force. The speakers are glued onto the phone, not wired.
结论
Andrew Lam
于04/23/15注册
101 声望
撰写一个指南
团队
Cal Poly, Team 14-9, Amido Spring 2015 Cal Poly, Team 14-9, Amido Spring 2015 的会员
CPSU-AMIDO-S15S14G9
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 458
