跳转到主内容
Telstra Dave 4G ZTE T83 Logic Board Replacement
你所需要的
  1. Telstra Dave 4G ZTE T83 Logic Board Replacement, Digitiser Cable: 步骤 1 中的图像 1,1
    • Disconnect the digitizer cable from is socket, flip the brown clasp up from indicated edge and gently remove the cable.
  2. Telstra Dave 4G ZTE T83 Logic Board Replacement, Logic Board: 步骤 2 中的图像 1,3 Telstra Dave 4G ZTE T83 Logic Board Replacement, Logic Board: 步骤 2 中的图像 2,3 Telstra Dave 4G ZTE T83 Logic Board Replacement, Logic Board: 步骤 2 中的图像 3,3
    • Be careful of LCD connector on the underside of the board through all of these steps (see green).
    • Separate the logic board from front display. Apply heat to the front glass to loosen the adhesive, using a prying tool to separate the board. Be careful and move slowly, it is very strong.
    • Be careful to remove the display first from the right side as there are clips along the left side.
    • Ensure not to damage the LCD cable, remove once accessible by releasing the brown clasp from indicated side.
结论
Ryan
于08/19/15注册
1,414 声望
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 265
