跳转到主内容
简介
I've repaired this problem several times using this method and it works well.
  1. Kids pulled the cable connector off the back of the hello kitty TV
    • Kids pulled the cable connector off the back of the hello kitty TV
  2. Remove screws from back, there's 5 in this case circled in red.
    • Remove screws from back, there's 5 in this case circled in red.
    • Notice the parts container highlighted in orange always a good idea for screws.
    • Cookie circled in pink for good measure.
  3. asess damaged area once cover is off.
    • asess damaged area once cover is off.
  4. Beware the danger areas, Capacitors (especially big ones) can hold a charge for months, enough to throw you across the room and melt tools.
    • Beware the danger areas, Capacitors (especially big ones) can hold a charge for months, enough to throw you across the room and melt tools.
    • High voltage areas are outlined in red.
    • Delicate sensitive areas outlined in blue.
  5. iPhone 电池维修工具包
    只要 $29.99
    Buy Now
    iPhone 电池维修工具包
    只要 $29.99
    Buy Now
  6. remove both covers on video input box, use a small prying tool if necessary, but you should be able to remove them by hand as seen here.
    • remove both covers on video input box, use a small prying tool if necessary, but you should be able to remove them by hand as seen here.
  7. Use a soldering iron, and solder sucker to remove excess solder from the connector area. You can also use solder-absorbing braided wick.
    • Use a soldering iron, and solder sucker to remove excess solder from the connector area. You can also use solder-absorbing braided wick.
  8. identify, where the centre pin connector was ripped from the board.
    • identify, where the centre pin connector was ripped from the board.
    • Use needle-nose pliers to straighten out the tin bracket as much as possible. It does not need to be perfect, but this helps with the alignment of the connector to the back of the tv cover.
  9. Align the connector, ensuring the center pin can reach the the spot on the board where it needs to be re-connected.
    • Align the connector, ensuring the center pin can reach the the spot on the board where it needs to be re-connected.
    • Solder the barrel of the connector to the metal bracket first, try not to let it get too hot. You may want to use a solder gun with dual heat of at least 50 watts for this part.
    • When that's done don't forget to solder the center pin to the board using as little solder as possible, to ensure there's no grounding to the metal cover.
  10. Re-seat both covers using needle nose pliers to ensure they're seated properly.
    • Re-seat both covers using needle nose pliers to ensure they're seated properly.
  11. Carefully reconnect the coax jack.
    • Carefully reconnect the coax jack.
  12. Carefully replace the plastic cover. Replace cover screws.
    • Carefully replace the plastic cover. Replace cover screws.
    • Repairing is more environmentally responsible than disposing of a TV in a landfill. You are saving the environment from the Lead (Pb) glass from the rear of the CRT and Barium (Ba) glass in front screen.
    • There is very little danger of the CRT imploding or cracking if you use common sense, they are built for shipping and rough handling. The cadmium in the screen is unlikely to escape even during breakage, and is not much of an environmental hazard.
结论
7等其他人完成本指南。
brant
于2010年08月30日注册
222 信誉积分
撰写一个指南
cara memperbaiki warna
Abdullah Rojai - 回复
where can i get the connectors?
Minecraftmania - 回复
C'est très intéressant, Mais seulement si vous pouvez traduire en français
Mohamed Bouchouit - 回复
11.11.16 Francais en anglaise= French to english. It's very interesting. I only wish u'd translate into French!
Franchette DuBose-Burgess -
Nice work, what do use to take great pics?
Matt - 回复
添加评论
浏览统计数据:
过去的24小时: 16
过去的7天: 54
过去的30天: 237
总计 40,374
