简介
This will show you how to change the rocker switch on the Blaupunkt TV
你所需要的
Removing the power switch is quite simple. First open the case by removing all screws on the back panel, which are marked with an arrow. (ATTENTION: different lengths and strengths! - Remember which screw goes where when unscrewing).
Then carefully lift off the back panel and disconnect any cables that prevent the back panel from being lifted off. Now press the retaining clips that hold the switch in the TV housing together with needle-nose pliers and clip the switch out of the TV housing. (use a flat-blade screwdriver if necessary).
As mentioned before - connect the cable to the new switch and snap the snap-in switch back into the housing. Replace the back panel and screw the screws back in where they were unscrewed.
2等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
