跳转到主内容
加入维修社区 - 创建账户
本篇指南是分解流程而非维修指南。 如果您要维修您的Telescope,应参考我们的维修指南
  1. Telescope Teardown, Telescope Teardown: 步骤 1 中的图像 1,2 Telescope Teardown, Telescope Teardown: 步骤 1 中的图像 2,2
    • Here is the telescope with case.
    • Now the lens covers are removed and thumb screw(left to the eye piece lens cover) also which locks the inner tube for fixed focus.
  2. Telescope Teardown: 步骤 2 中的图像 1,3 Telescope Teardown: 步骤 2 中的图像 2,3 Telescope Teardown: 步骤 2 中的图像 3,3
    • Now we are going to remove the objective lens .
    • You can see a ring supporting the lens so turn it anticlockwise .
    • Avoid damage the lens while turning the ring.
    • The lens and the ring
  3. Telescope Teardown: 步骤 3 中的图像 1,3 Telescope Teardown: 步骤 3 中的图像 2,3 Telescope Teardown: 步骤 3 中的图像 3,3
    • Lets focus on eyepiece part.
    • Once again just turn the plastic cap like screw and you will get one lens of eyepiece mechanism.(In the image you can also see the thumb screw which is used to lock inner tube position)
    • Now point the open end of inner tube downwards,you will see a plastic cylinder.
  4. Telescope Teardown: 步骤 4 中的图像 1,2 Telescope Teardown: 步骤 4 中的图像 2,2
    • Now removing the cylinder you will get one more convex lens.
    • repeating the previous step you will see more cylinder and lenses (watch the image)
    • All the cylinder and lenses in the image are in the steel tube next to them .
  5. Telescope Teardown: 步骤 5 中的图像 1,2 Telescope Teardown: 步骤 5 中的图像 2,2
    • Finally the telescope is disassembled .
    • I hope you didn't waste 1 minute of your life .
Nitin Agrawal
于11/15/10注册
31 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 28
总计 7,460
