跳转到主内容
Telecaster Guitar String(s) Replacement
你所需要的
  1. Telecaster Guitar String(s) Replacement, Guitar String(s): 步骤 1 中的图像 1,3 Telecaster Guitar String(s) Replacement, Guitar String(s): 步骤 1 中的图像 2,3 Telecaster Guitar String(s) Replacement, Guitar String(s): 步骤 1 中的图像 3,3
    • Start with the low E string (the furthest on the right). Unwind the string by turning the tuning peg counter-clockwise.
    • Keep the string secure by placing one finger on the string's nut slot.
    • After unwinding the string, the segment coiled around the post will come loose. Pull the string out of the post.
  2. Telecaster Guitar String(s) Replacement: 步骤 2 中的图像 1,3 Telecaster Guitar String(s) Replacement: 步骤 2 中的图像 2,3 Telecaster Guitar String(s) Replacement: 步骤 2 中的图像 3,3
    • Uncoil the end of the string as much as possible.
    • Caution: Use caution in handling the ends of strings as they are extremely sharp.
    • Pull the end of the string through the bridge and out through the back of the guitar.
  3. Telecaster Guitar String(s) Replacement: 步骤 3 中的图像 1,3 Telecaster Guitar String(s) Replacement: 步骤 3 中的图像 2,3 Telecaster Guitar String(s) Replacement: 步骤 3 中的图像 3,3
    • Insert the pointed end of the new string through the corresponding hole on the back of the guitar.
    • Turn the guitar over and pull the string all the way through.
  4. Telecaster Guitar String(s) Replacement: 步骤 4 中的图像 1,3 Telecaster Guitar String(s) Replacement: 步骤 4 中的图像 2,3 Telecaster Guitar String(s) Replacement: 步骤 4 中的图像 3,3
    • There will be extraneous string length while replacing the 5th and 6th (furthest to the right) strings. Using a wire cutter, you may opt to trim the length of these strings.
    • Stretch out the replacement string and cut it about 3-4 peg lengths away from the peg of the string you're replacing. In this case, you are replacing the 5th string and will cut the string near the 2nd string peg.
  5. Telecaster Guitar String(s) Replacement: 步骤 5 中的图像 1,3 Telecaster Guitar String(s) Replacement: 步骤 5 中的图像 2,3 Telecaster Guitar String(s) Replacement: 步骤 5 中的图像 3,3
    • Insert the end of the cut string into the middle hole of the corresponding peg.
    • Keep pushing the end of the string to the bottom and bend the string until the outside segment touches the bottom of the guitar head.
  6. Telecaster Guitar String(s) Replacement: 步骤 6 中的图像 1,3 Telecaster Guitar String(s) Replacement: 步骤 6 中的图像 2,3 Telecaster Guitar String(s) Replacement: 步骤 6 中的图像 3,3
    • Pushing the end of the string to the bottom and the outside segment to the guitar head, turn the tuning peg clockwise.
    • When the string is tight enough, you may release it. Make sure the string fits securely within the nut slot.
    • Using a tuner of your choice, tighten the guitar string until it matches the correct pitch.
终点
2等其他人完成本指南。
Jasper
于04/11/21注册
187 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 41
过去 30 天: 173
总计 8,687
