跳转到主内容
Tektro Aires Disc Brakes Brake Pad Replacement
你所需要的
  1. Tektro Aires Disc Brakes Brake Pad Replacement, Brake Pad: 步骤 1 中的图像 1,1
    • Bend the retention pins straight using a pair of needle nose pliers.
  2. Tektro Aires Disc Brakes Brake Pad Replacement: 步骤 2 中的图像 1,2 Tektro Aires Disc Brakes Brake Pad Replacement: 步骤 2 中的图像 2,2
    • Loosen the two mounting bolts using a 5mm Hex Key.
    • Different bike models will have the mounting points in different locations.
  3. Tektro Aires Disc Brakes Brake Pad Replacement: 步骤 3 中的图像 1,1
    • After removing the bolts pull of the brake caliper from the brake disc.
  4. Tektro Aires Disc Brakes Brake Pad Replacement: 步骤 4 中的图像 1,1
    • Using the needle nose pliers remove the retention pin by pulling on it.
  5. Tektro Aires Disc Brakes Brake Pad Replacement: 步骤 5 中的图像 1,1
    • Remove the brake pads by pulling on them and releasing them from the caliper.
  6. Tektro Aires Disc Brakes Brake Pad Replacement: 步骤 6 中的图像 1,1
    • Place the spring on the new Tektro Disc Brake Pad as shown.
    • The other brake pad will go on the spring opposite the first brake pad.
结论
  • The steps for the front wheel are the same as the back wheel.
  • Follow steps in reverse for reassembly.
2等其他人完成本指南。
1指南评论
Why did you change the spelling of brakes half way through?
Brian Haddock - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 43
过去 30 天: 184
总计 7,770
