简介
This guide will teach you how to remove the side panels of your Tefal Thick N Thin Toaster 815032, the plastic parts that guard the access to the inner mechanism. Doing this will allow you to access the heating parts and other inner components of the toaster in case they require maintenance or need a replacement due to malfunctions of the device.
你所需要的
Turn the toaster upside down.
Remove the four 10 mm screws from the bottom of the toaster using a TR9 Torx screwdriver.
Remove the 14 mm Torx-slot combination screw on the opposite side of the toaster's lever with a TR9 Torx screwdriver.
Remove the 11 mm Torx-slot combination screw near the toaster's lever with a TR9 Torx screwdriver.
