跳转到主内容
Tefal Thick N Thin Toaster 815032 Side Panels Replacement
你所需要的
  1. Tefal Thick N Thin Toaster 815032 Side Panels Replacement, Side Panels: 步骤 1 中的图像 1,3 Tefal Thick N Thin Toaster 815032 Side Panels Replacement, Side Panels: 步骤 1 中的图像 2,3 Tefal Thick N Thin Toaster 815032 Side Panels Replacement, Side Panels: 步骤 1 中的图像 3,3
    • Turn the toaster upside down.
    • Remove the four 10 mm screws from the bottom of the toaster using a TR9 Torx screwdriver.
    • Remove the 14 mm Torx-slot combination screw on the opposite side of the toaster's lever with a TR9 Torx screwdriver.
    • Remove the 11 mm Torx-slot combination screw near the toaster's lever with a TR9 Torx screwdriver.
  2. Tefal Thick N Thin Toaster 815032 Side Panels Replacement: 步骤 2 中的图像 1,1
    • Remove the side of the toaster that does not have the lever.
    • The side will just pop off, as you have removed the screw holding it in place.
  3. Tefal Thick N Thin Toaster 815032 Side Panels Replacement: 步骤 3 中的图像 1,2 Tefal Thick N Thin Toaster 815032 Side Panels Replacement: 步骤 3 中的图像 2,2
    • Remove the 10 mm screw from the top of the remaining side of the toaster using a TR9 Torx screwdriver.
    • This side will pop off as well once you have removed the screw.
    • The toaster's lever and heating slide will fall off with a simple pull.
结论
Kristen Gismondi
于11/12/14注册
82,707 声望
创作了202篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,430篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 8
总计 191
