你所需要的
Turn the toaster upside down.
Remove the four 10 mm screws from the bottom of the toaster using a TR9 Torx screwdriver.
Remove the 14 mm Torx-slot combination screw on the opposite side of the toaster's lever with a TR9 Torx screwdriver.
Remove the 11 mm Torx-slot combination screw near the toaster's lever with a TR9 Torx screwdriver.
Use an opening tool to pry back the metal tabs on the left and right corners of the toaster's front and back metal panels.
Pull off the front and back panels of the toaster.
Pry back the metal tabs on the corners of the front and back inner heating panels using an opening tool.
Remove both the front and back inner heating panels of the toaster.
