跳转到主内容
Teenage Engineering OP-1 Connector Board Replacement
你所需要的
  1. Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: 步骤 1 中的图像 1,3 Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: 步骤 1 中的图像 2,3 Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: 步骤 1 中的图像 3,3
    • Open the back panel by using a Jimmy on the side of the panel. Be careful not to damage the OP-1 coating.
    • Lift the back panel and remove it. The Connector Board is revealed.
  2. Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: 步骤 2 中的图像 1,3 Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: 步骤 2 中的图像 2,3 Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: 步骤 2 中的图像 3,3
    • Disconnect the flex connector by lifting it up with a spudger.
    • Remove the three Phillips screws. Do not lose the washer at the bottom screw.
    • Take out the connector board.
    • Make sure to keep the black rubber pad underneath the board.
  3. Teenage Engineering OP-1 Connector Board Replacement: 步骤 3 中的图像 1,2 Teenage Engineering OP-1 Connector Board Replacement: 步骤 3 中的图像 2,2
    • Don't forget the cover for the on/off switch.
    • Simply take it off from the old board and transfer it to the new board.
结论
47等其他人完成本指南。
44指南评论
Veeery useful , thank you !
mouchtouris alexandre - 回复
Even with the Jimmy I can't seem to get the back panel off... a video would be helpful :)
Shawn Ivie - 回复
Got the back panel off finally but my connector board won't come out.
Shawn Ivie - 回复
Ok... finally got the connector board out. It took a bit of gentle prying using a very small thin screw driver bit on each side of the connector board. Once I had the right side popped up a bit I was able to push on the input output jacks from the outside to get clearance. Removing the connector board and putting it back in resolved the power switch issues I was experiencing. No new connector board needed! :)
Shawn Ivie - 回复
Im so glad I was reading these comments. I had an OP1 with failing power as well, every bit more tougher touch would turn it off and on, or sometimes would have problems starting up.
I took it apart to see if something was bothering, and taking off the white power switch actually solved it haha.
Good I didnt order it yet!
J-J -
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 69
过去 30 天: 361
总计 51,812
