跳转到主内容
Teddy Ruxpin Housing Cover Replacement
你所需要的
  1. Teddy Ruxpin Housing Cover Replacement, Battery: 步骤 1 中的图像 1,2 Teddy Ruxpin Housing Cover Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the vest covering the back of the bear.
    • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
    • Captured screws will stay in place, no need to worry about losing this one!
  2. Teddy Ruxpin Housing Cover Replacement: 步骤 2 中的图像 1,1
    • Pull the tab outward to remove the protective plate for the batteries.
  3. Teddy Ruxpin Housing Cover Replacement: 步骤 3 中的图像 1,1
    • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
  4. Teddy Ruxpin Housing Cover Replacement, Arms: 步骤 4 中的图像 1,3 Teddy Ruxpin Housing Cover Replacement, Arms: 步骤 4 中的图像 2,3 Teddy Ruxpin Housing Cover Replacement, Arms: 步骤 4 中的图像 3,3
    • Cut the orange shirt and zip tie.
    • Remove the zip tie.
  5. Teddy Ruxpin Housing Cover Replacement: 步骤 5 中的图像 1,1
    • Cut across the back seam of the head of the bear along the arrow.
    • This damages the bear's exterior and will require resewing.
  6. Teddy Ruxpin Housing Cover Replacement: 步骤 6 中的图像 1,3 Teddy Ruxpin Housing Cover Replacement: 步骤 6 中的图像 2,3 Teddy Ruxpin Housing Cover Replacement: 步骤 6 中的图像 3,3
    • Remove the interior of the doll.
    • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
    • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
  7. Teddy Ruxpin Housing Cover Replacement: 步骤 7 中的图像 1,2 Teddy Ruxpin Housing Cover Replacement: 步骤 7 中的图像 2,2
    • Extract each arm button.
    • Pull on the stuffing of the bear and not the wire to remove the arm button.
  8. Teddy Ruxpin Housing Cover Replacement: 步骤 8 中的图像 1,2 Teddy Ruxpin Housing Cover Replacement: 步骤 8 中的图像 2,2
    • Pull off the rest of the outside layer of the bear.
  9. Teddy Ruxpin Housing Cover Replacement: 步骤 9 中的图像 1,1
    • Unplug the arms from the main body.
  10. Teddy Ruxpin Housing Cover Replacement, Housing Cover: 步骤 10 中的图像 1,3 Teddy Ruxpin Housing Cover Replacement, Housing Cover: 步骤 10 中的图像 2,3 Teddy Ruxpin Housing Cover Replacement, Housing Cover: 步骤 10 中的图像 3,3
    • Unscrew the eleven circled 12.5mm Phillips #1 screws.
    • Remove the top of the housing to access the electronics inside.
结论
另外一个人完成了本指南。
Jonny Brazil
于01/23/20注册
190 声望
撰写一个指南
团队
Cal Poly, Team S18-G5, White Winter 2020 Cal Poly, Team S18-G5, White Winter 2020 的会员
CPSU-WHITE-W20S18G5
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 499
