跳转到主内容
Teddy Ruxpin Arm Button Replacement
你所需要的
  1. Teddy Ruxpin Arm Button Replacement, Battery: 步骤 1 中的图像 1,2 Teddy Ruxpin Arm Button Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the vest covering the back of the bear.
    • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
    • Captured screws will stay in place, no need to worry about losing this one!
    If screw is missing could this be the problem
    nursejackie55 - 回复
  2. Teddy Ruxpin Arm Button Replacement: 步骤 2 中的图像 1,1
    • Pull the tab outward to remove the protective plate for the batteries.
  3. Teddy Ruxpin Arm Button Replacement: 步骤 3 中的图像 1,1
    • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
    I have already changed out the batteries and it still want com on.
    Wendy Nickel
    breezy_bear99 - 回复
  4. Teddy Ruxpin Arm Button Replacement, Arms: 步骤 4 中的图像 1,3 Teddy Ruxpin Arm Button Replacement, Arms: 步骤 4 中的图像 2,3 Teddy Ruxpin Arm Button Replacement, Arms: 步骤 4 中的图像 3,3
    • Cut the orange shirt and zip tie.
    • Remove the zip tie.
  5. Teddy Ruxpin Arm Button Replacement: 步骤 5 中的图像 1,1
    • Cut across the back seam of the head of the bear along the arrow.
    • This damages the bear's exterior and will require resewing.
  6. Teddy Ruxpin Arm Button Replacement: 步骤 6 中的图像 1,3 Teddy Ruxpin Arm Button Replacement: 步骤 6 中的图像 2,3 Teddy Ruxpin Arm Button Replacement: 步骤 6 中的图像 3,3
    • Remove the interior of the doll.
    • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
    • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
  7. Teddy Ruxpin Arm Button Replacement: 步骤 7 中的图像 1,2 Teddy Ruxpin Arm Button Replacement: 步骤 7 中的图像 2,2
    • Extract each arm button.
    • Pull on the stuffing of the bear and not the wire to remove the arm button.
  8. Teddy Ruxpin Arm Button Replacement: 步骤 8 中的图像 1,2 Teddy Ruxpin Arm Button Replacement: 步骤 8 中的图像 2,2
    • Pull off the rest of the outside layer of the bear.
  9. Teddy Ruxpin Arm Button Replacement: 步骤 9 中的图像 1,1
    • Unplug the arms from the main body.
结论
4等其他人完成本指南。
Lauren
于01/23/20注册
226 声望
创作了2篇指南
团队
Cal Poly, Team S18-G5, White Winter 2020 Cal Poly, Team S18-G5, White Winter 2020 的会员
CPSU-WHITE-W20S18G5
4 名成员
创作了7篇指南
4条评论
All you need are screwdrivers? The most important part is left out! New buttons? Where, how?
embalmerjules - 回复
And how do you replace it?! This just says how to take out old buttons!
Summer-Lynn Morente - 回复
So has anyone figured out how to replace the button?
knrobinson83 - 回复
The plastic part of the button is what broke in my daughter's Teddy Ruxpin. She had a similar toy with a button in its hand that she no longer played with, so I took the plastic button part out of the old toy and fit it onto Teddy Ruxpin. I used the same wires and threaded them through the plastic button, then resoldered the wires to the small board in the button. Works perfectly now.
Eliza Zollicoffer - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 6
总计 976
