跳转到主内容
Teddy Bear Nose Replacement
你所需要的
  1. Teddy Bear Nose Replacement, Nose: 步骤 1 中的图像 1,2 Teddy Bear Nose Replacement, Nose: 步骤 1 中的图像 2,2
    • Rip out about five inches of stitches from around the bear's snout.
  2. Teddy Bear Nose Replacement: 步骤 2 中的图像 1,2 Teddy Bear Nose Replacement: 步骤 2 中的图像 2,2
    • Remove stuffing from around the bear's snout.
  3. Teddy Bear Nose Replacement: 步骤 3 中的图像 1,1
    • Flip the fabric of the snout inside out to expose the back of the plastic nose.
  4. Teddy Bear Nose Replacement: 步骤 4 中的图像 1,2 Teddy Bear Nose Replacement: 步骤 4 中的图像 2,2
    • Remove the plastic backing of the teddy bear's nose (if it's still there). You may have to use pliers.
  5. Teddy Bear Nose Replacement: 步骤 5 中的图像 1,1
    • Pull the nose out of the front of the teddy bear’s face.
  6. Teddy Bear Nose Replacement: 步骤 6 中的图像 1,1
    • Push the front of the new nose through the existing hole in the teddy bear’s face.
  7. Teddy Bear Nose Replacement: 步骤 7 中的图像 1,1
    • Attach the nose backing on the inside of the teddy bear’s nose.
  8. Teddy Bear Nose Replacement: 步骤 8 中的图像 1,1
    • Restuff the teddy bear’s nose with the stuffing you took out.
    • You may need to add more stuffing if the bear’s nose looks flat or deflated.
  9. Teddy Bear Nose Replacement: 步骤 9 中的图像 1,1
    • Thread the needle with about 18 inches of thread the same color as the bear's fur or stitches.
  10. Teddy Bear Nose Replacement: 步骤 10 中的图像 1,3 Teddy Bear Nose Replacement: 步骤 10 中的图像 2,3 Teddy Bear Nose Replacement: 步骤 10 中的图像 3,3
    • Sew the teddy bear’s face using a whip stitch until the opening is completely closed.
    • For help with sewing a whip stitch, follow this guide: How to Sew a Whip Stitch.
  11. Teddy Bear Nose Replacement: 步骤 11 中的图像 1,2 Teddy Bear Nose Replacement: 步骤 11 中的图像 2,2
    • Once the face is completely sewn shut, knot the end of the thread, and cut off the excess.
终点
Nazib Khan
于09/28/21注册
193 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 27
过去 30 天: 109
总计 3,813
