跳转到主内容
Technostar Sandwich Toaster Thermal Fuse Replacement
你所需要的
  1. Technostar Sandwich Toaster Thermal Fuse Replacement, Thermal Fuse: 步骤 1 中的图像 1,1
    • Open the toaster.
    • Remove the four screws which attach the mold.
  2. Technostar Sandwich Toaster Thermal Fuse Replacement: 步骤 2 中的图像 1,2 Technostar Sandwich Toaster Thermal Fuse Replacement: 步骤 2 中的图像 2,2
    • Remove the mold to get access to the heating coil.
  3. Technostar Sandwich Toaster Thermal Fuse Replacement: 步骤 3 中的图像 1,1
    • Find the thermofuse.
  4. Technostar Sandwich Toaster Thermal Fuse Replacement: 步骤 4 中的图像 1,2 Technostar Sandwich Toaster Thermal Fuse Replacement: 步骤 4 中的图像 2,2
    • Cut the two wires that connect to the thermal fuse.
  5. Technostar Sandwich Toaster Thermal Fuse Replacement: 步骤 5 中的图像 1,2 Technostar Sandwich Toaster Thermal Fuse Replacement: 步骤 5 中的图像 2,2
    • Align the thermal fuse with the open wires.
    • Put the spade connectors over the wires.
    • Using pliers, clamp the wires together.
  6. Technostar Sandwich Toaster Thermal Fuse Replacement: 步骤 6 中的图像 1,1
    • Replace the molds.
    • Replace the four screws which attach the mold.
终点
4等其他人完成本指南。
2条评论
where did u find the replacement fuse? I need a thermal fuse for Breville BSG520XL Panini Duo Grill
mortaz - 回复
how do i test that the reason that my toaster is not working is actually the thermal fuse?
itzsabag - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 54
总计 4,355
