跳转到主内容
Teac DC-D2831 Drive Belt replacement
你所需要的
  1. Teac DC-D2831 Drive Belt replacement, Drive Belt: 步骤 1 中的图像 1,2 Teac DC-D2831 Drive Belt replacement, Drive Belt: 步骤 1 中的图像 2,2
    • Separate the turntable from the top of the record player by lifting straight up.
  2. Teac DC-D2831 Drive Belt replacement: 步骤 2 中的图像 1,1
    • Check the belt to see if it is off the motor or turntable. If the belt is damaged (tearing or lack of smoothness) replace the belt with a new one. If it is off track, realign accordingly.
    • Do not stretch the belt too far as it may break.
  3. Teac DC-D2831 Drive Belt replacement: 步骤 3 中的图像 1,3 Teac DC-D2831 Drive Belt replacement: 步骤 3 中的图像 2,3 Teac DC-D2831 Drive Belt replacement: 步骤 3 中的图像 3,3
    • Once the belt is ready to go, re-wrap the belt around the turntable wheel and, keeping it around the wheel, wrap it around the motor (indicated by the red circle).
    • It may be helpful to lay the record player on its side to keep the belt wrapped around both the motor and the turntable wheel.
  4. Teac DC-D2831 Drive Belt replacement: 步骤 4 中的图像 1,1
    • Once the belt has been re-applied and the turntable re-attached, stand the record player back up.
结论
To reassemble your device, follow these instructions in reverse order and complete the disassembly guide in reverse order.
2等其他人完成本指南。
Charles Lockner
于09/17/12注册
115 声望
创作了2篇指南
团队
Cal Poly, Team 2-61, Propen Fall 2012 Cal Poly, Team 2-61, Propen Fall 2012 的会员
CPSU-PROPEN-F12S2G61
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 7
总计 3,591
