跳转到主内容
Teac DC-D2831 Motor Replacement
你所需要的
  1. Teac DC-D2831 Motor Replacement, Motor: 步骤 1 中的图像 1,2 Teac DC-D2831 Motor Replacement, Motor: 步骤 1 中的图像 2,2
    • Remove the three brass screws using a phillips #1 screwdriver.
  2. Teac DC-D2831 Motor Replacement: 步骤 2 中的图像 1,1
    • Cut the wires that are attached to the motor.
    • Be sure to note the attachment point so that the wires can be reattached to the new motor.
  3. Teac DC-D2831 Motor Replacement: 步骤 3 中的图像 1,3 Teac DC-D2831 Motor Replacement: 步骤 3 中的图像 2,3 Teac DC-D2831 Motor Replacement: 步骤 3 中的图像 3,3
    • Using the phillips #1 screwdriver, remove the three screws that are holding the circular mounting bracket to the motor.
    • Remove the circular mounting bracket from the motor.
  4. Teac DC-D2831 Motor Replacement: 步骤 4 中的图像 1,2 Teac DC-D2831 Motor Replacement: 步骤 4 中的图像 2,2
    • Attach the mounting bracket to the new motor.
    • Insert the new motor.
    • Flip the turntable over making sure the motor stays in place, and insert the screws underneath the turntable.
  5. Teac DC-D2831 Motor Replacement: 步骤 5 中的图像 1,1
    • The ends of the wires will need to be stripped before soldering.
    • Be extremely careful not to burn yourself while soldering.
    • Solder the wires cut wires onto the motor in the location recorded previously.
结论
To reassemble your device, follow these instructions in reverse order and complete the disassembly guide in reverse order.
Jake Hamilton
于09/19/12注册
167 声望
创作了2篇指南
团队
Cal Poly, Team 2-61, Propen Fall 2012 Cal Poly, Team 2-61, Propen Fall 2012 的会员
CPSU-PROPEN-F12S2G61
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,792
