跳转到主内容
Tea Kettle Switch Replacement
你所需要的
  1. Tea Kettle Switch Replacement, Switch: 步骤 1 中的图像 1,3 Tea Kettle Switch Replacement, Switch: 步骤 1 中的图像 2,3 Tea Kettle Switch Replacement, Switch: 步骤 1 中的图像 3,3
    • Before you start, disconnect the device from its power source.
    • Remove the two bottom screws.
    • Remove the two top screws.
    • Remove the handle from the kettle.
  2. Tea Kettle Switch Replacement: 步骤 2 中的图像 1,2 Tea Kettle Switch Replacement: 步骤 2 中的图像 2,2
    • Pull out the switch.
    • If you pull too hard, you may dislodge another part as well as the spring that are both positioned behind the switch.
  3. Tea Kettle Switch Replacement: 步骤 3 中的图像 1,1
    • Click the replacement switch back into the handle part.
  4. Tea Kettle Switch Replacement: 步骤 4 中的图像 1,1
    • Insert the light back into the switch.
    • This might take some extra attention, so be precise.
  5. Tea Kettle Switch Replacement: 步骤 5 中的图像 1,1
    • Place the handle part back on the frame.
  6. Tea Kettle Switch Replacement: 步骤 6 中的图像 1,1
    • Plug in the kettle.
    • Press down on the switch to check if it works again.
结论
6等其他人完成本指南。
3条评论
How much would it cost to repair this kettle switch live points?
Bheki Valoyi - 回复
How much would it cost to fix the tea kettle switch live points?
Bheki Valoyi - 回复
Can the kettle gadgets be replaced with another one
Michael Ombech - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 33
过去 30 天: 168
总计 24,976
