跳转到主内容
加入维修社区 - 创建账户
Taurus G2C Field Strip Disassembly
  1. Taurus G2C Field Strip Disassembly, The basics: 步骤 1 中的图像 1,2 Taurus G2C Field Strip Disassembly, The basics: 步骤 1 中的图像 2,2
    • WARNING: As a rule of thumb, whenever handling any firearm, treat the weapon as if it is loaded and be mindful of the muzzle of the firearm at all times! "I didn't know it was loaded" isn't an excuse and can't undo mistakes!
    • Before proceeding with this repair, be sure to clear the firearm of ammunition. Check, double check, and triple check to make sure there isn't a bullet in the chamber!
    • The Taurus G2C has a handy Loaded Chamber Indicator to show if there's a bullet in the chamber. Even if it's not showing loaded doesn't mean you should not check!
  2. Taurus G2C Field Strip Disassembly, Field Strip: 步骤 2 中的图像 1,2 Taurus G2C Field Strip Disassembly, Field Strip: 步骤 2 中的图像 2,2
    • For safety reasons, the serial number has been redacted.
    • After making sure the weapon is clear -no bullet in the chamber- , release the striker by pulling the trigger. This releases the tension on the striker and allows the slide to come forward.
    • Pull the slide back just a hair to release the tension on the disassembly latches. Pull downward on the disassembly latches on both sides while holding rearward pressure on the slide, then release the pressure on the slide.
  3. Taurus G2C Field Strip Disassembly, Separating the slide and the grip: 步骤 3 中的图像 1,3 Taurus G2C Field Strip Disassembly, Separating the slide and the grip: 步骤 3 中的图像 2,3 Taurus G2C Field Strip Disassembly, Separating the slide and the grip: 步骤 3 中的图像 3,3
    • Continue moving the slide forwards until the rear of the slide passes the guides the notches above the disassembly latches(pointed out in the last picture).
  4. Taurus G2C Field Strip Disassembly, Removing the recoil spring assembly: 步骤 4 中的图像 1,3 Taurus G2C Field Strip Disassembly, Removing the recoil spring assembly: 步骤 4 中的图像 2,3 Taurus G2C Field Strip Disassembly, Removing the recoil spring assembly: 步骤 4 中的图像 3,3
    • The recoil spring assembly is on the bottom of the barrel. It is held in place by the spring's own tension against a notch in the barrel (2nd picture) and its slot in the end of the slide.
    • While holding the slide with the muzzle pointing away from you, put your thumb or index finger on the rear-facing portion of the recoil spring assembly. Push the assembly forward to free it from the tension against the barrel, then release the tension and pull it out of its slot in the slide.
  5. Taurus G2C Field Strip Disassembly, Removing the barrel: 步骤 5 中的图像 1,3 Taurus G2C Field Strip Disassembly, Removing the barrel: 步骤 5 中的图像 2,3 Taurus G2C Field Strip Disassembly, Removing the barrel: 步骤 5 中的图像 3,3
    • With the recoil spring assembly no longer holding the barrel in, the barrel can now be removed.
    • Move the barrel slightly towards the bottom of the slide
    • Push the barrel forward a little bit to allow enough space to clear the ejector (not pictured)
  6. Taurus G2C Field Strip Disassembly: 步骤 6 中的图像 1,2 Taurus G2C Field Strip Disassembly: 步骤 6 中的图像 2,2
    • Lift the barrel out of the slide.
  7. Taurus G2C Field Strip Disassembly, Finished!: 步骤 7 中的图像 1,1
    • Always treat any gun as if it were loaded at all times. Also always be mindful of the direction your muzzle is pointed.
    • You're finished! You have now successfully field stripped a Taurus G2C.
结论
To reassemble your weapon, follow these instructions in reverse order.
17等其他人完成本指南。
Josh Boyd
于10/25/16注册
868 声望
撰写一个指南
5指南评论
Hello Josh. This is Matthew. Thanks for the field stripping instructions. Just wanted to let you know people are using your instructions. Safe shooting and have a good day
Matthew Mackey - 回复
Hey Matthew! Glad to hear people are able to use my guide! Thanks for reaching out!!
Josh Boyd -
Just wanted you to know I just used your information on taking apart my pistol. Great info.
mkoc1018 - 回复
Awesome, glad to hear it helped! Safe shooting and pass the knowledge along!
Josh Boyd -
Thanks for the great tutorial. Very clear and concise.
Jonathon Covey - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 97
过去 30 天: 582
总计 60,623
