跳转到主内容
Tatung TAC-6G Light Element Replacement
你所需要的
  1. Tatung TAC-6G Light Element Replacement, Light Element: 步骤 1 中的图像 1,1
    • Start with the device standing upright.
  2. Tatung TAC-6G Light Element Replacement: 步骤 2 中的图像 1,1
    • Remove the 11mm Phillips screw from below the power component panel.
  3. Tatung TAC-6G Light Element Replacement: 步骤 3 中的图像 1,1
    • Pull the panel away from the rice cooker.
    • Remove the 9mm Phillips screw from behind the power component dashboard that is connected to the light plate.
  4. Tatung TAC-6G Light Element Replacement: 步骤 4 中的图像 1,1
    • Pull the light plate from the power component panel.
  5. Tatung TAC-6G Light Element Replacement: 步骤 5 中的图像 1,1
    • Flip the rice cooker device upside down.
  6. Tatung TAC-6G Light Element Replacement: 步骤 6 中的图像 1,2 Tatung TAC-6G Light Element Replacement: 步骤 6 中的图像 2,2
    • Remove the one 7mm Phillips screw from the side of the brass panel
    • Lift the brass plate off of the device and set it aside.
  7. Tatung TAC-6G Light Element Replacement: 步骤 7 中的图像 1,1
    • Remove the 7mm Phillips screw holding the white and maroon colored wires that are connected to the heating element.
  8. Tatung TAC-6G Light Element Replacement: 步骤 8 中的图像 1,1
    • Remove the 10mm Phillips screw that connects the white, blue and black wires to the white plastic piece in the corner of the device.
  9. Tatung TAC-6G Light Element Replacement: 步骤 9 中的图像 1,1
    • Remove the 7mm Phillips screw that connects two white wires and one red wire to the heating "warm" switch.
  10. Tatung TAC-6G Light Element Replacement: 步骤 10 中的图像 1,1
    • Using your hand, pull out the light plate with the maroon red and black wires.
  11. Tatung TAC-6G Light Element Replacement: 步骤 11 中的图像 1,1
    • Replace the light plate dashboard.
结论
一条评论
Reverse the steps for reassembly.
Tom Anderson - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 622
