跳转到主内容
Taranis X9D & X9D Plus Hall Effect Gimbals Replacement
你所需要的
  1. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement, Hall Effect Gimbals: 步骤 1 中的图像 1,3 Taranis X9D & X9D Plus Hall Effect Gimbals Replacement, Hall Effect Gimbals: 步骤 1 中的图像 2,3 Taranis X9D & X9D Plus Hall Effect Gimbals Replacement, Hall Effect Gimbals: 步骤 1 中的图像 3,3
    • Place the device so that the bottom is facing up.
    • Slide the battery compartment open.
    • Pull the battery by the plastic connector (not the wires) and shim left and right until the cable disconnects.
  2. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: 步骤 2 中的图像 1,1
    • Remove the eight screws holding the gimbals to the front of the case using a 2.5 mm Hex key.
    • Push all switches forward or away from you (this will be important for reassembly).
  3. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: 步骤 3 中的图像 1,3 Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: 步骤 3 中的图像 2,3 Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: 步骤 3 中的图像 3,3
    • Remove six screws from the back of the device using a Phillips #0 screwdriver.
    • Ensure the switches are in the position from the previous step, as they are not held in place and can reverse direction.
    • Gently pull the back up and open the radio in the form of a book, with the battery compartment being the spine.
    • Lay the controller on its front so that as the last screw is removed, the two halves don't fall apart.
  4. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: 步骤 4 中的图像 1,2 Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: 步骤 4 中的图像 2,2
    • Detach a total of six connectors (three per gimbal).
    • Pull the gimbals out from the radio frame.
  5. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: 步骤 5 中的图像 1,2 Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: 步骤 5 中的图像 2,2
    • New gimbals come in left and right boxes, respectively, so as not to mix them up, as well as identical connections for a drop-in replacement.
    • New gimbals will include new hex bolts for the front, as the stock ones will not fit.
    • When dropping the new gimbals into place, the harnesses will face downwards on their respective side.
    • Do not press on the cables. Push down on the connectors with your thumbs.
  6. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: 步骤 6 中的图像 1,1
    • Reattach the eight screws back onto the frame of the controller using a 2.5 mm Hex key.
  7. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: 步骤 7 中的图像 1,2 Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: 步骤 7 中的图像 2,2
    • Close the radio back up like a book, and verify the switches are in the same position.
    • Reattach the six screws to the back panel using a Phillips #0 screwdriver.
  8. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: 步骤 8 中的图像 1,3 Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: 步骤 8 中的图像 2,3 Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: 步骤 8 中的图像 3,3
    • Reinsert the battery and the battery door.
    • Turn on the radio and verify the correct installation from the on-screen information (check the switch positions with the on-screen display).
    • New gimbals may require recalibration depending on the settings of your stock gimbals.
终点
Saad Irfan
于10/20/23注册
157 声望
撰写一个指南
团队
CSU Los Angeles, Team 13-2, Ribeiro Fall 2023 CSU Los Angeles, Team 13-2, Ribeiro Fall 2023 的会员
CSULA-RIBEIRO-F23S13G2
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 21
总计 461
