跳转到主内容
Tara Handle Replacement
  1. Tara Handle Replacement, Handle: 步骤 1 中的图像 1,1
    • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
    • Use a Tara tool to loosen the jam nuts on either side of the pump.
    • The bolts do not need to be loosened or removed, only the nuts need to be loosened.
  2. Tara Handle Replacement: 步骤 2 中的图像 1,3 Tara Handle Replacement: 步骤 2 中的图像 2,3 Tara Handle Replacement: 步骤 2 中的图像 3,3
    • Unscrew the lock bolts about half an inch.
    • The bolts do not need to be removed from the base.
  3. Tara Handle Replacement: 步骤 3 中的图像 1,2 Tara Handle Replacement: 步骤 3 中的图像 2,2
    • Pull the plastic bushing and handle straight up out of the pump.
    • If the bushing doesn't come up, loosen the lock bolts further.
  4. Tara Handle Replacement: 步骤 4 中的图像 1,2 Tara Handle Replacement: 步骤 4 中的图像 2,2
    • Lift up the handle and riser main until the joint between the two is at a comfortable height to work on.
  5. Tara Handle Replacement: 步骤 5 中的图像 1,3 Tara Handle Replacement: 步骤 5 中的图像 2,3 Tara Handle Replacement: 步骤 5 中的图像 3,3
    • Loosen the jam nut beneath the pump handle using the Tara tool.
  6. Tara Handle Replacement: 步骤 6 中的图像 1,2 Tara Handle Replacement: 步骤 6 中的图像 2,2
    • Unscrew the pump handle from the top of the riser main.
    • Make sure someone is tightly holding the lower portion of the riser main to prevent losing it down the well.
  7. Tara Handle Replacement: 步骤 7 中的图像 1,2 Tara Handle Replacement: 步骤 7 中的图像 2,2
    • Lift and remove the handle from the pump. Store the handle in a sanitary place to prevent contamination.
结论
Sam Goldheart
于10/18/12注册
465,854 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了17,198篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 15
总计 217
