跳转到主内容
Tara Foot Valve Replacement
你所需要的
  1. Tara Foot Valve Replacement, Handle: 步骤 1 中的图像 1,1
    • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
    • Use a Tara tool to loosen the jam nuts on either side of the pump.
    • The bolts do not need to be loosened or removed, only the nuts need to be loosened.
  2. Tara Foot Valve Replacement: 步骤 2 中的图像 1,3 Tara Foot Valve Replacement: 步骤 2 中的图像 2,3 Tara Foot Valve Replacement: 步骤 2 中的图像 3,3
    • Unscrew the lock bolts about half an inch.
    • The bolts do not need to be removed from the base.
  3. Tara Foot Valve Replacement: 步骤 3 中的图像 1,2 Tara Foot Valve Replacement: 步骤 3 中的图像 2,2
    • Pull the plastic bushing and handle straight up out of the pump.
    • If the bushing doesn't come up, loosen the lock bolts further.
  4. Tara Foot Valve Replacement: 步骤 4 中的图像 1,2 Tara Foot Valve Replacement: 步骤 4 中的图像 2,2
    • Lift up the handle and riser main until the joint between the two is at a comfortable height to work on.
  5. Tara Foot Valve Replacement: 步骤 5 中的图像 1,3 Tara Foot Valve Replacement: 步骤 5 中的图像 2,3 Tara Foot Valve Replacement: 步骤 5 中的图像 3,3
    • Loosen the jam nut beneath the pump handle using the Tara tool.
  6. Tara Foot Valve Replacement: 步骤 6 中的图像 1,2 Tara Foot Valve Replacement: 步骤 6 中的图像 2,2
    • Unscrew the pump handle from the top of the riser main.
    • Make sure someone is tightly holding the lower portion of the riser main to prevent losing it down the well.
  7. Tara Foot Valve Replacement: 步骤 7 中的图像 1,2 Tara Foot Valve Replacement: 步骤 7 中的图像 2,2
    • Lift and remove the handle from the pump. Store the handle in a sanitary place to prevent contamination.
  8. Tara Foot Valve Replacement, Pump Rod: 步骤 8 中的图像 1,3 Tara Foot Valve Replacement, Pump Rod: 步骤 8 中的图像 2,3 Tara Foot Valve Replacement, Pump Rod: 步骤 8 中的图像 3,3
    • Screw the T-handle onto the top of the riser main.
  9. Tara Foot Valve Replacement: 步骤 9 中的图像 1,2 Tara Foot Valve Replacement: 步骤 9 中的图像 2,2
    • Tighten the jam nut up against the base of the T-handle.
  10. Tara Foot Valve Replacement: 步骤 10 中的图像 1,3 Tara Foot Valve Replacement: 步骤 10 中的图像 2,3 Tara Foot Valve Replacement: 步骤 10 中的图像 3,3
    • Use the T-handle to push the riser main back down into the well.
  11. Tara Foot Valve Replacement: 步骤 11 中的图像 1,3 Tara Foot Valve Replacement: 步骤 11 中的图像 2,3 Tara Foot Valve Replacement: 步骤 11 中的图像 3,3
    • Once the riser main hits the bottom, turn the T-handle while pushing down.
    • This will hook the foot valve onto the traveling valve, allowing you to pull the two out of the well together.
    • You should feel some resistance if the foot valve is successfully attached.
  12. Tara Foot Valve Replacement: 步骤 12 中的图像 1,2 Tara Foot Valve Replacement: 步骤 12 中的图像 2,2
    • Use the T-handle to pull the riser main straight up out of the well.
    • Take care to pull up slowly to ensure the foot valve does not get released from the hook at the end of the riser main.
  13. Tara Foot Valve Replacement: 步骤 13 中的图像 1,2 Tara Foot Valve Replacement: 步骤 13 中的图像 2,2
    • Continue pulling the riser main up from the well.
    • Pull the riser main until the base of the T-handle is at a comfortable height to work on.
  14. Tara Foot Valve Replacement: 步骤 14 中的图像 1,3 Tara Foot Valve Replacement: 步骤 14 中的图像 2,3 Tara Foot Valve Replacement: 步骤 14 中的图像 3,3
    • Loosen the jam nut from the base of the T-handle.
    • Unscrew the T-handle from the top of the riser main.
    • Remove the T-handle, making sure to hold the remaining end of the riser main to prevent dropping it down the well.
  15. Tara Foot Valve Replacement: 步骤 15 中的图像 1,3 Tara Foot Valve Replacement: 步骤 15 中的图像 2,3 Tara Foot Valve Replacement: 步骤 15 中的图像 3,3
    • Continue to pull the riser main out of the well.
  16. Tara Foot Valve Replacement: 步骤 16 中的图像 1,3 Tara Foot Valve Replacement: 步骤 16 中的图像 2,3 Tara Foot Valve Replacement: 步骤 16 中的图像 3,3
    • Keep pulling until the first joint is exposed.
    • Lift the joint up to a comfortable working height.
  17. Tara Foot Valve Replacement: 步骤 17 中的图像 1,3 Tara Foot Valve Replacement: 步骤 17 中的图像 2,3 Tara Foot Valve Replacement: 步骤 17 中的图像 3,3
    • Use two wrenches to loosen the top section of riser main from the lower section.
    • Unscrew the top section of the riser main.
    • Make sure someone is holding the remaining section of the riser main.
  18. Tara Foot Valve Replacement: 步骤 18 中的图像 1,3 Tara Foot Valve Replacement: 步骤 18 中的图像 2,3 Tara Foot Valve Replacement: 步骤 18 中的图像 3,3
    • Remove the top section of the riser main.
  19. Tara Foot Valve Replacement: 步骤 19 中的图像 1,1
    • Lay the first section of riser main in a sanitary place to prevent contamination.
    • Repeat the previous procedure to remove the remaining sections of the riser main from the well.
    • Lay each new piece in the order it was removed to aid in reassembly.
  20. Tara Foot Valve Replacement: 步骤 20 中的图像 1,3 Tara Foot Valve Replacement: 步骤 20 中的图像 2,3 Tara Foot Valve Replacement: 步骤 20 中的图像 3,3
    • The last section of riser main will have the traveling valve screwed on to the end, and the foot valve hooked onto the traveling valve.
    • Be careful not to allow the foot valve to release from the hook by pulling slowly on the riser main.
  21. Tara Foot Valve Replacement: 步骤 21 中的图像 1,3 Tara Foot Valve Replacement: 步骤 21 中的图像 2,3 Tara Foot Valve Replacement: 步骤 21 中的图像 3,3
    • Lift and twist the foot valve to unhook it from the traveling valve.
  22. Tara Foot Valve Replacement: 步骤 22 中的图像 1,1
    • Once the riser main and valves have been removed from the well, place a rag over the top to prevent accidentally dropping anything down the well.
  23. Tara Foot Valve Replacement, Foot Valve: 步骤 23 中的图像 1,3 Tara Foot Valve Replacement, Foot Valve: 步骤 23 中的图像 2,3 Tara Foot Valve Replacement, Foot Valve: 步骤 23 中的图像 3,3
    • Inspect the foot valve for signs of wear or damage.
  24. Tara Foot Valve Replacement: 步骤 24 中的图像 1,3 Tara Foot Valve Replacement: 步骤 24 中的图像 2,3 Tara Foot Valve Replacement: 步骤 24 中的图像 3,3
    • When reassembling the pump, drop the foot valve down the well in the proper orientation, and follow the directions in reverse.
结论
Sam Goldheart
于10/18/12注册
465,870 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了17,218篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 23
总计 543
