跳转到主内容
Tapwave T2907US Zodiac 2 Battery Replacement
你所需要的
  1. Tapwave T2907US Zodiac 2 Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the four Torx T5 screws from the back panel.
  2. Tapwave T2907US Zodiac 2 Battery Replacement: 步骤 2 中的图像 1,1
    • Wedge a spudger in between the front and back panel.
    • Apply leverage downwards to the spudger in order to remove the back panel.
  3. Tapwave T2907US Zodiac 2 Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Slide the battery out from under the brown wire-tape.
    • Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
  4. Tapwave T2907US Zodiac 2 Battery Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
终点
2等其他人完成本指南。
Daniel Wiseman
于01/20/12注册
133 声望
创作了6篇指南
团队
Cal Poly, Team 10-33, Amido Winter 2012 Cal Poly, Team 10-33, Amido Winter 2012 的会员
CPSU-AMIDO-W12S10G33
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 14
总计 1,273
