跳转到主内容
Tapwave T2907US Zodiac 2 Analog Stick Replacement
你所需要的
  1. Tapwave T2907US Zodiac 2 Analog Stick Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the four Torx T5 screws from the back panel.
  2. Tapwave T2907US Zodiac 2 Analog Stick Replacement: 步骤 2 中的图像 1,1
    • Wedge a spudger in between the front and back panel.
    • Apply leverage downwards to the spudger in order to remove the back panel.
  3. Tapwave T2907US Zodiac 2 Analog Stick Replacement, Battery: 步骤 3 中的图像 1,1
    • Slide the battery out from under the brown wire-tape.
    • Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
  4. Tapwave T2907US Zodiac 2 Analog Stick Replacement: 步骤 4 中的图像 1,1
    • Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
  5. Tapwave T2907US Zodiac 2 Analog Stick Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Unscrew the 2 Philips #00 screws on each end of the motherboard.
  6. Tapwave T2907US Zodiac 2 Analog Stick Replacement: 步骤 6 中的图像 1,1
    • Pull off the black memory card slot piece with tweezers.
  7. Tapwave T2907US Zodiac 2 Analog Stick Replacement: 步骤 7 中的图像 1,1
    • Unscrew the 2 Philips #00 screws on each side of the charging port.
  8. Tapwave T2907US Zodiac 2 Analog Stick Replacement: 步骤 8 中的图像 1,2 Tapwave T2907US Zodiac 2 Analog Stick Replacement: 步骤 8 中的图像 2,2
    • Disconnect 2 brown wire-tape ends from each end of the motherboard. Gently pull straight out with tweezers.
  9. Tapwave T2907US Zodiac 2 Analog Stick Replacement: 步骤 9 中的图像 1,1
    • Pull the motherboard and screen component diagonally up and left away from the auxiliary port entrance to remove.
    • Glue connecting the auxiliary port to the casing may make it difficult to remove. Gently apply force as needed.
  10. Tapwave T2907US Zodiac 2 Analog Stick Replacement: 步骤 10 中的图像 1,1
    • Disconnect the 2 brown wire-tape ends from the left side of the battery slot on the motherboard using tweezers.
  11. Tapwave T2907US Zodiac 2 Analog Stick Replacement: 步骤 11 中的图像 1,3 Tapwave T2907US Zodiac 2 Analog Stick Replacement: 步骤 11 中的图像 2,3 Tapwave T2907US Zodiac 2 Analog Stick Replacement: 步骤 11 中的图像 3,3
    • Disconnect the large brown wire-tape from the motherboard.
    • Peel the black tape back from the wire-tape using tweezers.
    • Lift the black, hinged, plastic lock with tweezers to release the wire-tape.
    • The screen and motherboard components can now be separated from each other.
  12. Tapwave T2907US Zodiac 2 Analog Stick Replacement, Analog Stick: 步骤 12 中的图像 1,1
    • Use tweezers to remove analog stick straight upwards from its component on the motherboard.
    • It should lock into place when installing a new one.
结论
Daniel Wiseman
于01/20/12注册
133 声望
创作了6篇指南
团队
Cal Poly, Team 10-33, Amido Winter 2012 Cal Poly, Team 10-33, Amido Winter 2012 的会员
CPSU-AMIDO-W12S10G33
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 14
总计 947
