跳转到主内容
加入维修社区 - 创建账户
Taping a Cracked Front Panel
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Taping a Cracked Front Panel, Taping a Cracked Front Panel: 步骤 1 中的图像 1,3 Taping a Cracked Front Panel, Taping a Cracked Front Panel: 步骤 1 中的图像 2,3 Taping a Cracked Front Panel, Taping a Cracked Front Panel: 步骤 1 中的图像 3,3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered. For particularly bad breaks, you may need to lay down two layers.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Protect your eyes! This procedure will cause small pieces of glass to fly directly toward your face. Do not attempt without safety glasses.
结论
Sam Goldheart
于10/18/12注册
475,300 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,855篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 187
