跳转到主内容
Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018)
你所需要的
  1. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018), Taillight Bulb: 步骤 1 中的图像 1,1
    • Open the trunk of your vehicle.
  2. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): 步骤 2 中的图像 1,1
    • Locate the fabric access cover.
    • The fabric access cover is located right behind the the taillight.
  3. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): 步骤 3 中的图像 1,1
    • Gently pull out the access panel.
  4. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): 步骤 4 中的图像 1,3 Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): 步骤 4 中的图像 2,3 Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): 步骤 4 中的图像 3,3
    • Start unscrewing the large plastic screw counter-clockwise.
  5. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): 步骤 5 中的图像 1,1
    • Place the screw in a safe spot.
  6. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): 步骤 6 中的图像 1,2 Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): 步骤 6 中的图像 2,2
    • Remove the taillight assembly by gently wiggling it out with both hands.
  7. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): 步骤 7 中的图像 1,3 Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): 步骤 7 中的图像 2,3 Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): 步骤 7 中的图像 3,3
    • Unplug the taillight power plug by pinching both tabs to release the plug.
  8. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): 步骤 8 中的图像 1,1
    • Pinch the two release tabs towards each other and lift the bulb bracket out of the tail housing.
  9. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): 步骤 9 中的图像 1,3 Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): 步骤 9 中的图像 2,3 Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): 步骤 9 中的图像 3,3
    • Gently turn the bulb counter-clockwise until you can pull it out.
    • Don't squeeze the bulb too hard as it could break.
结论
Krystian Krys
于01/16/23注册
169 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 21
过去 7 天: 117
过去 30 天: 474
总计 4,716
