跳转到主内容
Tagital T9X Speaker Replacement
你所需要的
  1. Tagital T9X Speaker Replacement, Back Cover: 步骤 1 中的图像 1,1
    • With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
    • These screws are extremely easy to lose. Be sure to store them in a safe place.
  2. Tagital T9X Speaker Replacement: 步骤 2 中的图像 1,1
    • Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
    • The power, return, and volume buttons are not firmly secured to the panel; it is likely they will fall off in the process of removing the panel.
  3. Tagital T9X Speaker Replacement, Speaker: 步骤 3 中的图像 1,1
    • Detach speaker wires from motherboard.
    • The wires are fragile and may break off while handling them.
  4. Tagital T9X Speaker Replacement: 步骤 4 中的图像 1,1
    • Use the plastic spudger to remove speaker from the back panel.
结论
一条评论
Hi. I need a replacement speaker for my tagital t9x. What part number should I look up?
Jerry - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 132
