跳转到主内容
Tagital T9X Camera Replacement
你所需要的
  1. Tagital T9X Camera Replacement, Back Cover: 步骤 1 中的图像 1,1
    • With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
    • These screws are extremely easy to lose. Be sure to store them in a safe place.
  2. Tagital T9X Camera Replacement: 步骤 2 中的图像 1,1
    • Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
    • The power, return, and volume buttons are not firmly secured to the panel; it is likely they will fall off in the process of removing the panel.
  3. Tagital T9X Camera Replacement, Camera: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using tweezers, carefully remove the cloth covering from the ribbon connector for the camera.
  4. Tagital T9X Camera Replacement: 步骤 4 中的图像 1,1
    • Use the tip of the spudger or your fingernail to flip up the small flap on the ZIF connector.
    • Carefully remove the ribbon cable from the connector.
  5. Tagital T9X Camera Replacement: 步骤 5 中的图像 1,1
    • Remove the camera from its position at the top of the tablet.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 161
