跳转到主内容
Tagital T10 Battery Replacement
你所需要的
  1. Tagital T10 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Always make sure your device is completely powered off before performing repairs.
    • Remove the two 4 mm Phillips head screws at the top of the device.
  2. Tagital T10 Battery Replacement: 步骤 2 中的图像 1,1
    • Carefully remove the back cover by using a plastic opening tool, moving all the way around the perimeter of the tablet.
    • Set the back cover aside.
    • The speakers are attached to the inside back cover, and are connected by wires to the motherboard of the tablet. Be careful not to rip these free when removing the back.
  3. Tagital T10 Battery Replacement: 步骤 3 中的图像 1,2 Tagital T10 Battery Replacement: 步骤 3 中的图像 2,2
    • Locate the red and black wires that connect the battery to the motherboard.
    • Carefully peel away the tape that keeps the wires secured to the back of the display screen.
  4. Tagital T10 Battery Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Be sure to use tweezers when near the soldering iron because it is hot.
    • Soften the old solder by heating it with the soldering tool, so that the wires can be removed with tweezers.
  5. Tagital T10 Battery Replacement: 步骤 5 中的图像 1,1
    • Heat up the battery with the iOpener Heat tool in order to soften the adhesive that keeps the battery in place.
    • The iOpener Heat tool gets very hot, so be careful that you don't burn yourself.
  6. Tagital T10 Battery Replacement: 步骤 6 中的图像 1,2 Tagital T10 Battery Replacement: 步骤 6 中的图像 2,2
    • Remove the battery from the device with the plastic opening tool.
    • It may be difficult to remove so try reheating the iOpener and don't be afraid to use a good amount of force.
结论
2等其他人完成本指南。
Cody D'Amato
于09/26/16注册
303 声望
创作了2篇指南
团队
USF Tampa, Team 14-5, Eyestone Fall 2016 USF Tampa, Team 14-5, Eyestone Fall 2016 的会员
USFT-EYESTONE-F16S14G5
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 914
