跳转到主内容
TackLife GSW01A Pump Assembly Replacement
你所需要的
  1. TackLife GSW01A Pump Assembly Replacement, Pump: 步骤 1 中的图像 1,2 TackLife GSW01A Pump Assembly Replacement, Pump: 步骤 1 中的图像 2,2
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • For safety Do Not make adjustments to your equipment without first disconnecting the spark plug.
    • Disconnect the spark plug by grabbing it and pulling it outwards.
  2. TackLife GSW01A Pump Assembly Replacement: 步骤 2 中的图像 1,3 TackLife GSW01A Pump Assembly Replacement: 步骤 2 中的图像 2,3 TackLife GSW01A Pump Assembly Replacement: 步骤 2 中的图像 3,3
    • Pull the siphon tube apart from connector.
    • Make sure to alleviate the pressure in the pump by squeezing the trigger, acknowledging where the tip is pointed.
    • Try to twist the high-pressure hose off by hand. If too tight, use Vise-Grips or Channellock pliers on the grip to loosen and remove the hose. Careful to maintain a steady grip lest the handle strip.
  3. TackLife GSW01A Pump Assembly Replacement: 步骤 3 中的图像 1,3 TackLife GSW01A Pump Assembly Replacement: 步骤 3 中的图像 2,3 TackLife GSW01A Pump Assembly Replacement: 步骤 3 中的图像 3,3
    • OPTIONAL: Remove handle for tool and hand clearance.
    • To remove the handle, unscrew the orange triangle knobs on both sides. With a firm grip on both sides pull handle apart from pressure washer.
  4. TackLife GSW01A Pump Assembly Replacement: 步骤 4 中的图像 1,3 TackLife GSW01A Pump Assembly Replacement: 步骤 4 中的图像 2,3 TackLife GSW01A Pump Assembly Replacement: 步骤 4 中的图像 3,3
    • Remove the 4 mounting bolts. (M8x20)
    • Use an open-ended or box wrench to loosen the bolts. There is not enough clearance for using a socket wrench.
    • Gently tap with a hammer, while safely holding the wrench in place on the bolt with the other hand to loosen the bolts.
    • Be careful not to strip the heads of bolts.
  5. TackLife GSW01A Pump Assembly Replacement: 步骤 5 中的图像 1,3 TackLife GSW01A Pump Assembly Replacement: 步骤 5 中的图像 2,3 TackLife GSW01A Pump Assembly Replacement: 步骤 5 中的图像 3,3
    • Remove the existing pump from motor shaft.
    • Retrieve the shaft key from the keyway inside the pump if it is not on the motor shaft keyseat.
  6. TackLife GSW01A Pump Assembly Replacement: 步骤 6 中的图像 1,1
    • Clean and lubricate the motor shaft and key.
    • Dirt and grit on shaft can possibly cause damage to the pump over time.
  7. TackLife GSW01A Pump Assembly Replacement: 步骤 7 中的图像 1,3 TackLife GSW01A Pump Assembly Replacement: 步骤 7 中的图像 2,3 TackLife GSW01A Pump Assembly Replacement: 步骤 7 中的图像 3,3
    • Correctly set the shaft key and hold in place while sliding the pump onto the motor shaft.
    • Align the keyway inside the pump with the key and slide the pump onto the motor shaft.
    • If key is not properly set, it could possibly cause damage to the pump or motor shaft.
  8. TackLife GSW01A Pump Assembly Replacement: 步骤 8 中的图像 1,3 TackLife GSW01A Pump Assembly Replacement: 步骤 8 中的图像 2,3 TackLife GSW01A Pump Assembly Replacement: 步骤 8 中的图像 3,3
    • Reinstall the 4 mounting bolts.
    • Rotate the pump so that the hose feeds are properly positioned, and bolt holes are aligned with holes on motor.
  9. TackLife GSW01A Pump Assembly Replacement: 步骤 9 中的图像 1,3 TackLife GSW01A Pump Assembly Replacement: 步骤 9 中的图像 2,3 TackLife GSW01A Pump Assembly Replacement: 步骤 9 中的图像 3,3
    • Reattach the hoses.
    • Reattach handle if removed in earlier steps (OPTIONAL step #3).
  10. TackLife GSW01A Pump Assembly Replacement: 步骤 10 中的图像 1,3 TackLife GSW01A Pump Assembly Replacement: 步骤 10 中的图像 2,3 TackLife GSW01A Pump Assembly Replacement: 步骤 10 中的图像 3,3
    • Screw the orange triangular knobs back on.
    • Reattach the spark plug.
    • Verify all connections are snug tight before operating the pressure washer.
结论
3等其他人完成本指南。
2条评论
I'm getting milky oil I want to change pump on my tacklife pressure washer 3200 psi what is a good pump?I cant find OEM pump from the number on pump?What size shaft?
Jason Blood - 回复
My pump leaks. Do you know of a gasket kit? What type of replacement oil is used thank you
G Barnes - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 41
总计 1,296
